Limits to Automatic Bed compensation? March 04, 2014 02:11PM |
Re: Limits to Automatic Bed compensation? March 12, 2014 04:42PM |
Re: Limits to Automatic Bed compensation? March 12, 2014 04:47PM |
Re: Limits to Automatic Bed compensation? March 12, 2014 05:11PM |
Re: Limits to Automatic Bed compensation? March 13, 2014 04:34AM |
Re: Limits to Automatic Bed compensation? March 13, 2014 04:45AM |
Jon Steward
Thanks I'll do exactly that.
Just found the old forum posts on bed levelling to go through.
Jon
[forums.reprap.org]Quote
Run the nozzle out to the outer corners of the bed, any difference in these corners (while moving the nozzle in the plus minus y-direction) is caused by the outer y-rod, this misalignment if any, is mirrored in the outer bed corners
Use nozzle measurements to adjust the y-axis-end-plates so the rods are at the same hight in both ends
Re: Limits to Automatic Bed compensation? March 13, 2014 07:05AM |
ormerod168
Re: Limits to Automatic Bed compensation? March 13, 2014 08:10AM |
Davek0974
ormerod168
Can say a vernier caliper be used to align the two rods to the table surface first?
Just trying to find a way of parallelling them without continuously running the bed up and down.
Re: Limits to Automatic Bed compensation? March 13, 2014 10:29AM |
auser
not homez.g and homeall.g?Quote
dc42
edit homex.g and homey.g
Re: Limits to Automatic Bed compensation? March 13, 2014 01:28PM |
ormerod168
... so there's no easy way I'm afraid, its a trail and error thing
Erik
Re: Limits to Automatic Bed compensation? March 13, 2014 04:24PM |
Re: Limits to Automatic Bed compensation? March 13, 2014 04:46PM |
Re: Limits to Automatic Bed compensation? March 14, 2014 03:43AM |
Re: Limits to Automatic Bed compensation? March 15, 2014 03:46AM |
Re: Limits to Automatic Bed compensation? March 15, 2014 04:11AM |
Jon Steward
...It's not too obvious to me but I've tried to slacken the black acrylic Y bracket to adjust but it's quite solid, not much adjustment.
Am I in the right area to adjust?
Re: Limits to Automatic Bed compensation? March 15, 2014 04:39AM |
Re: Limits to Automatic Bed compensation? March 15, 2014 05:08AM |
Jon Steward
Thanks that's the one to adjust. Now the bed is visually flat when running square.g
Do you have any tips on fine tuning?
Also, does running setbed.g do anything at this stage? Can't say that I've noticed any difference after running that file.
