Filament feeder slipping March 08, 2014 07:08PM |
Re: Filament feeder slipping March 08, 2014 07:14PM |
Re: Filament feeder slipping March 08, 2014 07:21PM |
Re: Filament feeder slipping March 08, 2014 07:31PM |
Re: Filament feeder slipping March 08, 2014 07:37PM |
Re: Filament feeder slipping March 08, 2014 09:10PM |
Re: Filament feeder slipping March 09, 2014 01:36AM |
Re: Filament feeder slipping March 09, 2014 04:22AM |
Re: Filament feeder slipping March 09, 2014 02:01PM |
Re: Filament feeder slipping March 09, 2014 05:42PM |
Re: Filament feeder slipping March 09, 2014 05:54PM |
Re: Filament feeder slipping March 09, 2014 09:03PM |
Re: Filament feeder slipping March 10, 2014 03:27AM |
rayhicks
....have you checked that the hot-end temperature is right? (on top of your PLA not being right as you suggest, it could be that there's a problem with your thermistor or its serial resistor - and the nozzle isn't being held at the right temperature because the temperature is being over-reported)....
Ray
Re: Filament feeder slipping March 10, 2014 05:06AM |
groneorm
Added 2 extra washer to large gear assembly just for good measure, although not seeing any wear from large gear rubbing off on extruder housing.
Re: Filament feeder slipping March 10, 2014 09:28AM |
groneorm
Printing with extruder motor current set to E1200 solved the feeding slippage. But it might also introduce a sligtly hotter steppermotor. I didnt take any reaing with the default values unfortunately. I would say it is at 40-45C after ~10 minutes of printing.
I have tried and measure the nozzle temp but I find it quite hard. Used first a IR-Thermometer gun, witch naild the hotbeds 60C on kapton but i have avery hard time getting any relevant temps from the hotheadarea. Also tried a digital stakethermometer, only got up to 170-180C reading so when head was set for 240.
Does anyone have a reliable method for checking the hotend temperature? wuold be great.
Re: Filament feeder slipping March 10, 2014 06:25PM |
Orm Ext % Off 50 43 -14,00% 70 56 -20,00% 100 86 -14,00% 120 99 -17,50% 140 114 -18,57% 160 128 -20,00% 180 140 -22,22% 200 151 -24,50% 220 164 -25,45% 240 174 -27,50% 260 184 -29,23% 280 193 -31,07% Degrees Celsius
Re: Filament feeder slipping March 10, 2014 07:36PM |
Re: Filament feeder slipping March 10, 2014 07:37PM |
Re: Filament feeder slipping March 10, 2014 08:25PM |
dc42
If you are using my latest firmware 057t - dc42 then you can reprogram the thermistor resistance at 25 C and thermistor beta. See the checkin comment for details.
rayhicks
groneorm - the standard thermistor should have a resistance of 100k at 25°C - can you hold it at that temperature and measure its resistance with a multimeter? I've had three duets (original from RRP, returned because of manufacturing fault on the 5V regulator, a T3P3 duet, which I still have, and the warranty replacement from RRP which I still have), the first two both under-read hotend temperature at ambient (-4 to +4 say for a temperature of around 18 °C) and over-read at high temperature - I tabulated the results here [forums.reprap.org] a while ago. Mine actually agreed with external measurement around 100°C though, yours reads low all the way through the range that you've reported. I recently started using the warranty replacement, and this seems to be spot-on (I haven't retested over the full temperature tange, but it agrees with external measurement at ambient now). Recently dc42 raised the question of whether the series resistor (which is used in tandem with the thermocouple to give a voltage that the duet can turn into a temperature) had a close enough tolerance - it would seem in my case that there is some difference between duets (since I haven't changed anything other than duet boards - no change in thermistor or its position, or the connections between) so I would tend to think that the series resistor does vary between boards. You might have a very extreme series resistor, or your thermistor might be out of spec (which is why I suggested checking the resistance at 25°C - if this checks out then you could try taping it to an external probe and holding it in kettle steam, which should show 100 on the external and let you measure the resistance at 100°C - this will let you calculate the beta for that temperature range and check it against the "spec" beta of 4066 where beta = (T1*T2)/(T2-T1) * ln(R1/R2) - all temps in Kelvin (°C+273.15)- I can't find a spec sheet for the thermistor with the beta on (or what range the beta is valid for unfortunately). If the thermistor checks out the next step would be to check the series resistor and/or the voltage feeding the divider ( the series resistor is R19 and should measure 1K, one end connects to the thermistor, the other end should be at 3.3V when the duet is powered up). If the thermistor doesn't check out, you can either plug your calculated beta into the software, dc42 has recently added the feature of changing betas using gcodes, or you should be able to get a replacement from RRP.
Ray
PS - it's very unlikely that the issue lies in the heater cartridge unless it's bullying the thermistor into lying to cover up its failure also, if anything, your external thermometer will be under-reading because of cooling effects, so the thermistor/duet error may be greater than you measured, but it won't be less
Re: Filament feeder slipping March 10, 2014 08:38PM |
Re: Filament feeder slipping March 10, 2014 10:49PM |
Re: Filament feeder slipping March 11, 2014 03:22AM |
dmould
..I used a thermocouple thermometer (RS part number 206-3722) The K type thermocouple that comes with the instrument has a lead that is long enough and thin enough to fit down the bowden tube. I removed the filament, took the bowden tube out of the extruder and fed the thermocouple down the tube till it bottomed in the molten plastic left in the nozzle, so the reading is about as accurate as you could get.
Dave
(#106)
Re: Filament feeder slipping March 11, 2014 04:22AM |
rayhicks
Note the beta I gave in my last email is actually incorrect - the beta for the extruder thermistor should be 4138 (just in case you end up going in this direction).
It may also be a bad idea to measure the resistance of R19 directly (directly probing both ends of the resistor should be OK, but might result in damaging the thermistor input pin on the chip if the input voltage is exceeded by your meter and there's a connection to ground) - a safer method of testing would be to substitute a 100K resistor (if you have one) for the thermistor which should give a reading around 25°C from pronterface, and substituting a piece of wire, which should give a reading around 5000°C (I think, I'll have to check on mine tomorrow), and can check what temperatures are reported for other resistor values if you'd like (presuming that you have a range of resistors lying around - if you do, then let me know what values you have),
Ray
Re: Filament feeder slipping March 11, 2014 05:07AM |
Re: Filament feeder slipping March 11, 2014 06:22AM |
dc42
Attached is a spreadsheet that I use to calculate thermistor resistance from temperature. Bear in mind that if you are using firmware prior to 057t-dc42 then the temperature resolution for the hot end thermistor is about 5C at room temperature.
dc42
Re: Filament feeder slipping March 11, 2014 07:11AM |
Re: Filament feeder slipping March 11, 2014 07:42AM |
Re: Filament feeder slipping March 11, 2014 09:18AM |
Re: Filament feeder slipping March 11, 2014 09:22AM |
Warranty t3p3? t3p3t res temp temp temp short -9890.8 2235.3 -9890.8 9850 84.5 82.5 82.5 99900 24 3.6 7.5
Re: Filament feeder slipping March 11, 2014 09:24AM |
