Hot End Thermistor Issues March 11, 2014 09:19AM |
Re: Hot End Thermistor Issues March 11, 2014 09:29AM |
Re: Hot End Thermistor Issues March 11, 2014 10:10AM |
Re: Hot End Thermistor Issues March 11, 2014 11:18AM |
Re: Hot End Thermistor Issues March 11, 2014 12:03PM |
Re: Hot End Thermistor Issues March 11, 2014 12:54PM |
Re: Hot End Thermistor Issues March 11, 2014 12:58PM |
Re: Hot End Thermistor Issues - POSSIBLE fix March 11, 2014 01:55PM |
Re: Hot End Thermistor Issues March 11, 2014 02:14PM |
dc42
I've just spotted a design issue that may affect the thermistor readings. The 1K reference resistors are connected directly to the 3.3V supply, however the VDDANA and ADVREF inputs to the chip are both connected to 3.3V via LC networks. So the voltage on VDDANA and ADVREF will be lower than the voltage feeding the 1K resistors by the voltage drop in the inductors. This will cause the thermistors to read colder.
Unfortunately I can't find a specification or part number for the inductors, so I can't work out the voltage drop. I may try to measure it, then it may be possible to allow for it by adjusting the ADC reading slightly.
It would have been better to connect the 1k resistors to ADVREF instead of to +3.3V.
Checking again, ADVREF agrees to the last millivolt with the highend going to the 1k resistors, I don't see any drop over the inductor either. I calculated (see the crossing post above) that there's approximately a 6mV error between the actual voltage and the voltage that the ADC is reporting, or about 50 ADC counts at 13bits.Quote
rayhicks
I checked the ADVREF voltage at the junction between C64 and L5, and it reads the same as the voltage being fed to R19 and R21 (3.278V within 0.7% of spec - I wondered if the ADC range was being distorted by a problem on that line),
Re: Hot End Thermistor Issues March 11, 2014 06:12PM |
12 BIT Parameter | Conditions | Min | Typ |Max| Units Offset error (Oe) | VDDIN 3.0V to <3.6V Single ended, DIFF=0, OFF=x, GAIN=xx| -30 |+11.5 |+56 |LSB 10 BIT Parameter | Conditions | Min|Typ |Max| Units Offset Error |all gain, Differential or Single ended, no calibration|-8 |+3 |+20 |LSB
Re: Hot End Thermistor Issues March 11, 2014 08:04PM |
Re: Hot End Thermistor Issues March 11, 2014 08:25PM |
Re: Hot End Thermistor Issues March 12, 2014 04:25AM |
Re: Hot End Thermistor Issues March 13, 2014 04:59AM |
Re: Hot End Thermistor Issues March 13, 2014 05:42AM |
dc42
Re: Hot End Thermistor Issues March 14, 2014 08:40PM |
R ADC10b ADC13b T10-bit T13-bit 99800 1021.3 8170.7 -2.3 -1.0 82000 1019.2 8153.3 8.6 9.9 9980 938.2 7505.9 81.8 81.9 28000 996.2 7969.5 48.8 49.1 6760 899.5 7196.3 95.0 94.9 990 516.9 4135.4 172.7 172.6 119.3 116.6 933.1 300.7 300.6
Re: Hot End Thermistor Issues March 14, 2014 09:14PM |
Re: Hot End Thermistor Issues March 16, 2014 04:36PM |
Re: Hot End Thermistor Issues March 17, 2014 08:20AM |
Re: Hot End Thermistor Issues March 18, 2014 09:09AM |
