Ninja flex March 11, 2014 11:58AM |
Re: Ninja flex March 11, 2014 12:13PM |
Re: Ninja flex March 11, 2014 12:41PM |
It feeds OK through the Bowden tube so long as it is under a reasonably constant pressure, but I found that it would occasionally stop feeding for a while following a retraction (but it self-starts after a short while), which is why I disabled retractions. Stringing is however an issue without the retractions - being rubbery it is like a compressed spring in the tube, and continues to extrude for quite a while after the feed stops. That was not an issue on the print I have just made because there are no non-printing moves across areas of space, so all strings fall onto plastic and are absorbed into the print. If you set retractions because stringing is an issue, I would think it would need to be quite big (6mm or more) to be effective because of the need to take up the "spring", and maybe keep a bit of a push on the filament feeding into the extruder to help it restart feeding. It is possible the feed issue is due to a problem in my extruder, (though it works fine with ABS). I haven't taken it apart to clean for quite a while, and it is possible that the hobbed bolt it a bit clogged. With ABS, the teeth "bite" into the plastic filament, but ninja flex just deforms temporarily so there are no teeth marks and possibly the grip is not quite as strong.Quote
GregL
Looks pretty good Dave.
You say it is not well suited to a Bowden tube - so how did you feed it?
Greg
Re: Ninja flex March 11, 2014 06:09PM |
Re: Ninja flex March 11, 2014 06:31PM |
Re: Ninja flex March 11, 2014 06:46PM |
Radian
Your timing is perfect Dave - I have some white Ninjaflex on order to try out. I saw adafruit using it for LED diffusers: [www.adafruit.com] and fancied a go. Your final print looks fantastic!
Re: Ninja flex March 11, 2014 07:24PM |
rayhicks
That does look good Dave - on a scale of polypropylene (eg milk bottle lid) to silicone rubber, how flexible would you say it is, and on the same scale, how hard?
For the stringiness/retraction difficulty did you try slic3r's "Extra length on restart" (which the tooltip says is seldom needed - but this might be that one time...),
Ray
Re: Ninja flex March 11, 2014 07:35PM |
Re: Ninja flex March 12, 2014 05:33AM |
Re: Ninja flex April 24, 2014 07:53AM |
Re: Ninja flex April 24, 2014 08:36AM |
Re: Ninja flex April 24, 2014 08:42AM |
Re: Ninja flex April 24, 2014 09:12AM |
balidey
Many thanks to Dave for the setting suggestions.
I am mid print now using some Ninja Flex.
So far no bobbling, seems to be stuck onto the Kapton OK. Layers look like they are bonding well.
Its not just a plain rubber tube, the top tapers in to form a duck bill valve.
Re: Ninja flex April 24, 2014 05:08PM |
Re: Ninja flex April 24, 2014 05:12PM |
Re: Ninja flex April 25, 2014 07:34AM |
balidey
Couldn't take any decent pictures of it finished, camera phone is rubbish, so I will update in the morning with better pics.
But the item is great.
Its a 25mm bore, 45mm high approx 1.5mm wall that then tapers inwards to a slot, height is another 45mm above the lower cylinder.
Its a 'duck bill check valve' if anyone wants to google it to see what we were making.
The exact item we want was not available. A rubber moulding company wanted an order for 1,000.
Instead £5 worth of Ninja Flex from ebay is enough for us to print 4.
Its an odd material. Very flexible and soft on the roll, but when printed it takes on more of a plasticised feel to it. But still flexible enough for what we wanted it for. Squeezing the slot on the top of our check valve required very little pressure, it opens up nicely, springs back to the original shape.
So tempted to order 1kg of it now.
If the dual / triple print head ever gets up and running on the Ormerod I think a PLA / Ninja Flex dual material fused print would be amazing. Like a plastic / rubber co-extruded seal.
Re: Ninja flex August 17, 2014 08:00AM |
Re: Ninja flex August 17, 2014 08:33AM |
