Just a little bit smaller... March 14, 2014 07:24AM |
Re: Just a little bit smaller... March 14, 2014 08:12AM |
Re: Just a little bit smaller... March 14, 2014 08:31AM |
Re: Just a little bit smaller... March 14, 2014 12:29PM |
Re: Just a little bit smaller... March 14, 2014 12:42PM |
Re: Just a little bit smaller... March 14, 2014 01:01PM |
ian
(...) However, this can make reprinting parts a little more difficult. The best compromise is to select 'External perimeters first' in 'Print Settings > Layers and perimeters > advanced'. That way, the inner layer won't push the outer layer even further into the hole.
I hope that helps.
Ian
RepRapPro tech support
Re: Just a little bit smaller... March 14, 2014 01:38PM |
raffybuffy
@ormerod168 No, I have done the thin wall test but just to test the print quality, I don't have a digital caliper, but with my caliper the thin wall seems to be of the correct size of 0,75mm. If I have understood the test correctly, if the size of the wall correspond to the size of the "perimeters extrusion width" it should be ok or not? I'm trying to understand but for me it's a really new world
Re: Just a little bit smaller... March 14, 2014 02:19PM |
ormerod168
I just think it sounds a bit strange that your perimeter extrusion with is 0.75 - what are the setting in slic3r\print settings\advanced\default extrusion width? - mine is set as zero (auto)
Erik
Re: Just a little bit smaller... March 14, 2014 05:50PM |
raffybuffy
The default extrusion is set to zero as your, why do you think that is strange? I print with 0.25 layer height and the nozzle diameter is 0.5, I have understood that the correct setting for the perimeter estrusion width is 0.75 isn't correct?
..Extrusion Width Ratio is placed under the advanced options, so it's not necessary to change it at all and you shouldn't do it only if you really need a particular extrusion width. Just be careful not to set it to a smaller extrusion width than your nozzle size: the results are undefined in that case...
Re: Just a little bit smaller... March 16, 2014 02:08PM |
) measuring the dimension in netfabb (typically the hole of the hexnut and the hole for the bearing, but also any other dimension) so I understood that the dimension on Z are alway correct the problem are on x/y plane.
