Time to upgrade? March 15, 2014 05:06AM |
Re: Time to upgrade? March 15, 2014 05:25AM |
Re: Time to upgrade? March 15, 2014 05:32AM |
Re: Time to upgrade? March 15, 2014 05:40AM |
Davek0974
I think it's time to upgrade my firmware, is there a single, concise link to how to do it?
I really don't want to mess things up.
I have a laptop running pronterface on XP as my main control over USB, is that enough to do the upgrade?
Thanks
Re: Time to upgrade? March 15, 2014 06:29AM |
Re: Time to upgrade? March 15, 2014 07:10AM |
Davek0974
Do any alterations need to be made to pronterface to take advantage of the fast USB upload etc?
Re: Time to upgrade? March 15, 2014 07:22AM |
Re: Time to upgrade? March 15, 2014 07:38AM |
dc42
Davek0974
Yes, see [forums.reprap.org].
Re: Time to upgrade? March 15, 2014 08:22AM |
Davek0974
Not having much luck so far.
Dropped the file on the .com script, pressed erase then reset, installed the windows hardware bit then pressed enter and it say bossac is not recognized as an internal or external command, operable program or batch file.
Re: Time to upgrade? March 15, 2014 09:05AM |
Re: Time to upgrade? March 15, 2014 09:14AM |
Re: Time to upgrade? March 15, 2014 09:57AM |
Re: Time to upgrade? March 15, 2014 10:10AM |
bobtidey
Plus having made the jump in firmware you can switch to Ethernet and the iamburny web interface and forget pronterface altogether.
Re: Time to upgrade? March 15, 2014 01:10PM |
Re: Time to upgrade? March 15, 2014 01:51PM |
Re: Time to upgrade? March 15, 2014 02:01PM |
Re: Time to upgrade? March 15, 2014 02:46PM |
Davek0974
....and twisted my y axis bars a bit more parallel, it's just running a job now with zero bed compensation![]()
...Where is the new reprap.htm file downloaded from?.
Re: Time to upgrade? March 15, 2014 02:54PM |
Re: Time to upgrade? March 15, 2014 03:28PM |
Davek0974
Thanks, so if I'm on the 'net, I just need the reprap.remote.htm renamed and put in the www folder?
Will try tomorrow hopefully.
The new firmware appears to be working well
Re: Time to upgrade? March 16, 2014 07:00AM |
Re: Time to upgrade? March 16, 2014 07:07AM |
Re: Time to upgrade? March 16, 2014 07:46AM |
Re: Time to upgrade? March 16, 2014 07:59AM |
Re: Time to upgrade? March 16, 2014 08:20AM |
Re: Time to upgrade? March 16, 2014 12:38PM |
Re: Time to upgrade? March 16, 2014 03:29PM |
Re: Time to upgrade? March 16, 2014 04:09PM |
Re: Time to upgrade? March 16, 2014 04:30PM |
Davek0974
Well I've updated the htm file but I can't connect, it's on the wrong subnet 192.168.1.14 where I need something like 192.168.0.230
I tried sending M552 P192.168.0.230 but it has no effect.
Connecting... Printer is now online. >>>M552 SENDING:M552 IP address: 192.168.1.80 >>>M552 P192.168.0.230 SENDING:M552 P192.168.0.230 >>>M552 SENDING:M552 IP address: 192.168.0.230
Re: Time to upgrade? March 16, 2014 04:39PM |
dc42
Note: the M552, M553 and M554 commands you send do not take effect (other than changing the values reported back) until the next reboot - at which time any values in config.g will override them.
