To oil or not to oil?
March 15, 2014 08:30AM
I've printed about a kg of filament now and have never oiled any part of the printer - no worrying noises to report so far, but increasingly feeling like I ought to be doing something on the preventative maintenance front! - should I oil, and if so what bits, what with and how often? All input, however controversial, gratefully received spinning smiley sticking its tongue out
Re: To oil or not to oil?
March 15, 2014 08:53AM
I would guess the only parts are the round slide rods, just a little light oil once in a while.
The bearings do not work that hard so I feel they should go for a long time.
Also look for signs of rubbing or wear and tear etc.
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
March 15, 2014 08:54AM
You should definitely oil the threaded rod with light machine oil.
Like a 3-in-1 or similar?
March 15, 2014 08:56AM
Yes. Not wd40 because that leaves a residue.
March 15, 2014 08:57AM
Yes that should do it
March 15, 2014 09:20AM
I had problems with my original 5mm Z-axis nut (lots of swarf and then it started to sieze up), I replaced it with a long nut (it's 20-25mm long), and used a WD40 PEN to dab it on the Z-axis lead screw, and all the rods... That was weeks ago, and I've done a lot of printing since then...With no problems.
I will dab some more WD40 on later today for good measure. If you've only got a spray can of WD40 then I'd suggest you spray it out side in to a platic cap, then use a paint brush to dab some on the thread and rods. I wouldnt spray anything on the printer, as you'll be weeks cleaning it up...
eye popping smiley
March 15, 2014 09:39AM
Another good thought Kim, thanks....BTW, I'm printing out your revised fan duct even as I type - kudos, looks great smileys with beer - really hoping it'll sort out a few curling issues I'm having on overhangs...
March 15, 2014 10:12AM
Wd40 is not good on rails etc, when it dries it leaves a waxy horrible residue behind, not good stuff.
I use a long brass nut on my z screw too, 3-in-1 on it and it's working very nicely.
March 15, 2014 11:15AM
Hi MrCrispi, hope you enjoy using the Fan-Duct. Just make sure you seal around the Heat Sink to stop the air blowing out.
I used 5 min apoxy, but UHU, or Silicon will do. The revised bit is the adapter plate, which allows you to use the Modified X-Motor mount if you move the I.R.Probe.
I now have one of DC42s No.2 kits here that I'll be making an adapter plate for.
Kim..
March 15, 2014 01:42PM
I'm using WAHL Clipper Oil (Boots the Chemists £4), thin clear and no residue, intended for hair clipper lubrication and thinner than 3-in-1. Just don't drip it on the bed or you'll be cleaning for ever! The rails, both bearings that bear on the Z upright and the X-carriage back bearing seem to be the essentail points. I'm avoiding the filament feeder as one drop on the filament would be really nasty.
Steve.
March 15, 2014 07:55PM
Singer sewing machiine oil is also quite a good choice for this type of job.
March 16, 2014 04:33AM
Clipper and machine oil are very similar, both fine light oils, clipper oil might be food grade but that's irrelevant here, both good choices though.
