How to replace stepper controler on Duet March 22, 2014 05:13PM |
Re: How to replace stepper controler on Duet March 22, 2014 06:12PM |
Re: How to replace stepper controler on Duet March 22, 2014 07:20PM |
Re: How to replace stepper controler on Duet March 22, 2014 08:26PM |
Re: How to replace stepper controler on Duet March 23, 2014 12:31AM |
Re: How to replace stepper controler on Duet March 23, 2014 05:29AM |
Re: How to replace stepper controler on Duet March 23, 2014 06:24AM |
Re: How to replace stepper controler on Duet March 23, 2014 06:29AM |
epninety
I'd start with a fresh blade in the scalpel, cut each of the legs at the device body. Then remove the legs from the pcb with small soldering iron. (Sounds bad but I've never broken a pad doing this - use the tip of a rounded blade, and slice vertically downwards)
Re: How to replace stepper controler on Duet March 23, 2014 06:37AM |
Re: How to replace stepper controler on Duet March 23, 2014 09:00AM |
Radian
No disrespect but I personally I think this is just too risky. The levering action as the leg parts company with the chip puts a lifting force on the pad. I used to remove small-outlne packs with 0.05" leads this way but I think I was getting away with it because the wider tracks typically had greater adhesion. As soon as I started doing it on packages with 0.5mm spaced leads I started ruining PCB's so switched to hot air removal.
