Replacement ALuminium X-Rib And X-Plate... March 24, 2014 07:01AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 24, 2014 01:05PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 24, 2014 01:38PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 24, 2014 02:59PM |
Laser Mal
At the moment I cannot get the Z axis to zero consistently, looks like the bed is not parallel to the X axis. Anyone else had that problem?
Re: Replacement ALuminium X-Rib And X-Plate... March 24, 2014 03:28PM |
Laser Mal
It should be nowhere near that price. I run a small business laser cutting parts for Model Engineers, I cut out the two y axis end plates in 5mm Aluminium for £7 each, The acrylic cracked. I also made some 1mm shims in steel as the ground steel bars were too long for the aluminium extrusion. At the moment I cannot get the Z axis to zero consistently, looks like the bed is not parallel to the X axis. Anyone else had that problem?
Malcolm
Re: Replacement ALuminium X-Rib And X-Plate... March 24, 2014 06:05PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 26, 2014 05:47AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 26, 2014 06:45PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 26, 2014 07:15PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 26, 2014 07:21PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 26, 2014 07:53PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 26, 2014 08:37PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 26, 2014 08:42PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 01:31AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 03:27AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 06:10AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 06:14AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 06:35AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 06:36AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 06:37AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 06:47AM |
PaulHam
How would the weight compare to the acrylic parts?
If the aluminium is heavier would the extra weight put more strain on the Z axis screw/nut?
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 07:31AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 08:03AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 08:30AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 08:53AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 11:02AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 12:29PM |
Re: Replacement ALuminium X-Rib And X-Plate... March 27, 2014 03:13PM |
appjaws1
Hi Dave,
Please put me down for one complete set of two y axis end plates and x-rib assembly
Thank you for your efforts
Paul
Re: Replacement ALuminium X-Rib And X-Plate... March 28, 2014 06:19AM |
Re: Replacement ALuminium X-Rib And X-Plate... March 28, 2014 09:15AM |
