Replacement ALuminium X-Rib And X-Plate...
Posted by Davek0974
Re: Replacement ALuminium X-Rib And X-Plate...
March 28, 2014 10:00AM
SlinBin
hmm, I'm late again yawning smiley
Please let me know if/when there will be another batch.
Enjoy you new parts ;-)
No you're bang on time, I ordered extras as I intend to keep all my parts available for some time yet smiling smiley
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
March 28, 2014 10:04AM
My 2p worth - countersunk to be avoided unless necessary - the self-centreing action just adds another potential inaccuracy problem. Not saying it will cause an issue, but no point designing one in if it's easily avoided.
Do the screws limit the available positions for the extruder, or the steel bearing tape? (Not got my machine in front of me).
March 28, 2014 02:26PM
epninety
Just checked and I think they might interfere with the motor for the extruder/s.
My solution would be to remove the three notches in the top edge and just have the extruder hanging anywhere between the screws. I just checked and it seems quite happy just clipped on to the top of the plate.
If this is a good idea, please let me know and I will email the laser cutter that a new DXF is on it's way and not to start on the file they have.
March 28, 2014 02:42PM
I've just tried hanging the extruder on the top, and I find it most unsatisfactory. It doesn't hang at a consistent angle. The extruder is heavily weighted towards one side, and the notch with the lip is needed to hold the extruder level. So I suggest countersunk screws.
March 28, 2014 03:14PM
Davek0974
SlinBin
Dear Davek0974
Just to clearify; You may take that as a request on my part ;-)
Thank you !
March 28, 2014 03:24PM
dc42
Fair enough, I'll leave it as-is and decide on screws after trialling my own one next week.
March 28, 2014 04:34PM
Hi
If you have one more I like one also.
Best regres
Per
March 28, 2014 06:45PM
Well 5mm plate isn't thick enough for much of a counterbore, and it really isn't much of an issue - so countersunk is fine.
If it does cause any kind of a distortion problem, then simply put it together with cap heads and washers, just long enough for the adhesive to go off - then remove the offending screws before fitting to the Ormerod smiling smiley
Plenty of surface area in the mating surface, so no super special adhesives required ...
March 29, 2014 04:58AM
I did get a quote from Henkel about gluing and there are several easy to use products in theirs or the Loctite range.
Definitely no room for counterbores, will check when the parts come in.
April 02, 2014 03:42AM
I did some checking with a scale print of the DXF file and the screw locations do NOT interfere with the extruder locations, should be an easy slot-in replacement and will be supplied with cap-head screws.
Should be with me Friday.
April 02, 2014 04:13PM
One set for me please.
Thanks
Jon
April 07, 2014 01:07PM
STATUS UPDATE....
I have to issue an apology, the laser cutters rang me early this morning to inform me of a machine problem over the weekend, my parts will now not be with me until early Wednesday morning.
I will be shipping them during Wednesday so there is a two day delay from my earlier dispatch date.
I can only apologise to you all and will hope to get them all out during Wednesday.
Dave
April 07, 2014 03:41PM
No need to hurry for mine, I will have no time to fit it this week.
Thanks for keeping us updated.
April 09, 2014 06:10AM
Parts are in, orders will be going out today smiling smiley
open | download - photo2.JPG (578.8 KB)
April 09, 2014 10:00AM
They look good, Dave. To look really sexy, they could be polished and anodised - black or electric blue anodising would look superb!
Dave
(#106)
April 09, 2014 02:40PM
dmould
Dave
(#106)
Yes that would look sweet but the price would be silly smiling smiley
They need some fettling with a file or carbide paper but they are not bad, only way to get better would be water jet but I just can't get the prices down into real-world figures.
April 09, 2014 02:49PM
Hi Dave could i get an pair too ?, between did you hear some from the beds ?
Greets Mario
April 10, 2014 07:59AM
Davek0974
dmould
Dave
(#106)
I was not implying that you should supply them that way, but that people who would like a good-looking Ormerod could do the polishing and anodising after receiving them. Long ago I experimented with DIY aluminium finishing using fabric dye after anodising to colour the metal, and did not get bad results (though it's quite a bit of effort, and commercial anodising/dying is not that expensive).
Giving aluminium a brush effect is quick & easy using a wire brush wheel on a drill, and that also looks pretty good.
Dave
(#106)
April 10, 2014 12:51PM
dmould
Davek0974
dmould
Dave
(#106)
Dave
(#106)
Of course, it's a good idea too, blue would go nicely i think.
April 11, 2014 03:02AM
URGENT - PLEASE READ....
A problem has been identified with the quality of one part of the X-rib kit. The thin reinforcing rib in some cases has developed a bow or bend in it, this is caused by internal stresses in the aluminium being released when the part was cut.
If you notice that the rib does not touch the large plate evenly along its length then do NOT use it as it will bend the main X-plate and give print alignment issues.
I am contacting the cutters today to try and organise a replacement part urgently, failing that then I will arrange another method of remedying this serious issue at no cost of course.
Please note that not all parts are affected, it seems only related to the earlier buyers and as soon as it was spotted, has been fixed on all later orders.
I can only apologise for this issue and ask that you bear with me while it is sorted out to your satisfaction.
I will update here as soon as I have more information.
Dave
April 11, 2014 07:44AM
Davek0974
Dave
Dave when I did mine I milled that surface to get it 100% straight, I just added 1 mm extra mtrl that I removed afterwards.
[forums.reprap.org]
/Joar
Edited 1 time(s). Last edit at 04/11/2014 07:46AM by Joar107.
April 11, 2014 02:18PM
Update....
I have replacement parts coming and hope to get this all straightened out next week (pun not intended smiling smiley ) new ribs will be sent to those early orderers that have bowed items, free of charge of course.
Once again, my apologies.
Dave
April 11, 2014 02:26PM
Hi Dave,
sand paper....
I solved the problemwinking smiley
Thanks for the excellent work donethumbs up
Dario
Ormerod 187
Firmware Electronics: Duet 0.6
Firmware Version:1.18.1 (2017-04-07)
Web Interface Version:1.15a
Slic3r 1.2.9a and Simplify3D 4.0.0
[www.dropbox.com]
April 11, 2014 02:36PM
Ormerod187
Hi Dave,
sand paper....
Dario
That's great, thanks for taking the effort to fix the issue.
Dave
April 13, 2014 06:10AM
Mine has a 2mm bow over the length of the thin rib.
Frankly the cut and finish of the whole thing is pretty poor, to say the least.
April 13, 2014 08:04AM
I forwarded images of these parts to another cutter and they confirmed that without using an argon process gas, these are fairly normal cut examples for laser and aluminium.
The trouble with using argon is that it pushes the cost up dramatically.
I probably will not be making more of these unless I can get better, all bowed ribs will be replaced at my expense, hopefully this week.
April 13, 2014 10:26AM
Davek0974
Hi Davek0974,
I need a great price (like what you've done) with a bit of work to do.....
But you can also show the right price for better quality ....
Thanks
Dario
Ormerod 187
[www.dropbox.com]
open | download - IMG_1283_.JPG (230.4 KB)
open | download - IMG_1284_.JPG (232.8 KB)
April 13, 2014 10:33AM
Ormerod187
Davek0974
Hi Davek0974,
Thanks
Dario
I think I see what you mean Dario, but unfortunately they must be ordered in batches, minimum qty is 25 sets and paid for in advance at order time.
It would not be possible to do both ways as there is no way to guarantee selling them.
April 13, 2014 01:58PM
Appreciate your efforts Davek0974
They will clean up into nice looking parts with a bit of attention in the shed, and more importantly, they will do the job - improving the ormerod smiling smiley
Dave
April 13, 2014 02:06PM
epninety
Dave
That's reassuring, thanks
If there is interest then I would be happy to get another batch cut.
