Slic3r ABS settigs help March 24, 2014 08:44AM |
Re: Slic3r ABS settigs help March 24, 2014 10:19AM |
Re: Slic3r ABS settigs help March 24, 2014 12:33PM |
Re: Slic3r ABS settigs help March 24, 2014 12:50PM |
G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion M140 S[first_layer_bed_temperature]; Set bed temperature G1 X2 Y50 F2000; Go to wait for warm position M116; Wait for all temperatures G10 P0 S[first_layer_temperature] R0 ; Set extruder temperature T0; Select extruder M116; Wait for all temperatures
Re: Slic3r ABS settigs help April 22, 2014 10:09AM |
Re: Slic3r ABS settigs help April 22, 2014 10:52AM |
Re: Slic3r ABS settigs help April 22, 2014 11:25AM |
Re: Slic3r ABS settigs help April 22, 2014 12:12PM |
Zonzo
Hi Dave, thanks for your advice.
My actually setting is similar to yours:
I print on UHU coating (UHU mix with water to make it fluid and then poured on the glass and tilt until it is completely covered, then put the glass on the hot bed and dry it while waiting the bed reach 110°)
Bed temperature 110° first layer and 100° the other
Extrusion temperature 240°
Printing speed 30mm/s (too high?, I have reduce to 25 but haven't try it)
Brim 10mm
Retraction 5mm at 45mm/s and whipe on retraction option enabled
With this setting I see that after some pressure the layer suffer delamination and in many case there are some bloob that interfere with print quality and leave my layer like step missing or belt slipping.
also the top layer don't look nice, it seem blooby and like the ABS was dragged...
When I start with ABS I change some setting about temperature but I haven't change the extrusion multiplier, could it be a problem?
Re: Slic3r ABS settigs help April 22, 2014 02:13PM |
Re: Slic3r ABS settigs help April 22, 2014 02:40PM |
Re: Slic3r ABS settigs help April 23, 2014 08:17AM |
Zonzo
Thanks Dave,
I'l print your gcode tomorrow in the morning so I can post the picture immediatly
PS: using a gcode viewer I see the print speed of your file to 30mm/s instead of 60 as I can see from the head of the gcode... is that a viewer error or a bug of Slic3r?
and also I can see from the gcode that you set the layer to 0.2 instead of the standard 0.24, is that the result of some test to have a better quality with ABS or it is the same of PLA?
Giuliano
Re: Slic3r ABS settigs help April 23, 2014 02:51PM |
Re: Slic3r ABS settigs help April 23, 2014 03:31PM |
Zonzo
Hi Dave,
the print was amazing!!!!
Your setting work really well for me!
Re: Slic3r ABS settigs help April 23, 2014 03:38PM |
Re: Slic3r ABS settigs help April 23, 2014 03:39PM |
Re: Slic3r ABS settigs help April 23, 2014 06:25PM |
Re: Slic3r ABS settigs help April 23, 2014 08:36PM |
Re: Slic3r ABS settigs help May 14, 2014 06:45AM |
Re: Slic3r ABS settigs help May 14, 2014 06:53AM |
88Zombies
I have just ordered some ABS to attempt to print, never tried before.
I read a reccommendation a while back about 1st printing some spare parts for the ormerod beacuse of the high temperatures used.
Which parts sould i make spares of??
Slightly nervous about printing in ABS, only just got the machine to a nice quality with PLA...
Re: Slic3r ABS settigs help May 14, 2014 07:50AM |
Re: Slic3r ABS settigs help May 14, 2014 10:13AM |
88Zombies
Hello!
Noob question @ dmould...
how do I apply your "config.ini" ABS printing settings?
do i add them mnually or is there a way to pop them in the 3 folders like the ormerod0.5 slic3r settings??
also..
Re: Slic3r ABS settigs help May 14, 2014 10:34AM |
Re: Slic3r ABS settigs help May 14, 2014 12:00PM |
88Zombies
Ah great,
will get some spares of this tonight..
what are the pieces circled in pink?
and where did you get teh mod circled in blue??
many thanks
