Still confuse with Z heights
Posted by antlvk
March 27, 2014 09:37PM
G92 Z0 is it the way to set the heights?
I see that auto leveling will save to flash. is it g92 z0 does too? but after restart my head still not the same heights
Re: Still confuse with Z heights
March 28, 2014 02:36AM
You have to zero z each time you turn on the printer, because it could have moved since the last power
My normal procedure is to
home all axis
Setbed
X100 Y100
Lower the z till you can feel it on the paper, then drop down 0.5mm
Then I run G92 Z0.24
Not sure if its the correct way but I've been getting good prints and consistent results.
March 28, 2014 03:31AM
PaulHam
0.5mm? Seems a lot to me I would suggest 0.05mm. If you do 0.5 and your first layer is 0.24 then the printer will try to start at -0.26
March 28, 2014 04:08AM
I drop until it vibrates on the paper then G92 Z0 then start printing, not failed yet (with the new bed support of course)
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
March 28, 2014 04:31AM
antlvk
No, auto levelling does not save to flash. The G31 parameters are saved to flash if you are using a recent build of my version of the firmware, but will be overridden by config.g if you set them there.
I've requested a mod to the Duet board to support voltage monitoring, so that the current XYZ coordinates can be saved to flash whenever power goes down.
March 28, 2014 04:38AM
ops i forgot i've put manual bed leveling in config.g spinning smiley sticking its tongue out
anyway so we need to Z0 everytime turn on then. thumbs up
So how high should i set the Z then cause when printing it will raise a heights of the first layer heights like 0.25 or 0.1 depends on settings.
SHould I just Z0 or the nozzle just stick to the bed?
March 28, 2014 05:20AM
No it will not stick, lower the (hot) nozzle slowly with a slip of thin paper under it until you can feel the vibrations of the fan in the paper, it will sound different too.
Pull the paper out, set G92 Z0, start printing, simples smiling smiley
March 28, 2014 05:49AM
Ow, that's something new. I'll try it later... still printing now
March 28, 2014 06:20AM
auser
PaulHam
sorry, typying on a ipad on a packed train. oops.
yes 0.05mm
March 28, 2014 06:43AM
I recently changed my bed, so the G31 setting in my config file was the old figure.
I was manually setting G92 Z0 for each print, but it was always running high.
Just re-done the G31 in the config file and now its printing perfectly, so it seems to ignore the manual G92 for me.
