Re: Z-height sensor - inductive? April 28, 2014 11:38AM |
dc42
dmould
In any case, many of the methods discussed would also not give the same height for different thicknesses of glass.
That's a good point.
I was going to develop a prototype inductive sensor next, however I'm leaning towards a solenoid-operated contact probe now. This will be independent of glass thickness and work anywhere on the bed. I've located a couple of solenoids that look suitable, and I am making inquiries.
There remains the issue of how to do x-homing. One possibility is to use a microswitch on the x-motor mount, although that would involve yet more wires running back to the Duet. Another is to keep an IR sensor on the hot end board just for IR homing. A third possibility is to mount a microswitch on the hot end board, such that its actuator lines up with the z-nut trap.
Re: Z-height sensor - inductive? April 28, 2014 12:15PM |
dmould
RS has a range of small 12V solenoids.
Re: Z-height sensor - inductive? April 28, 2014 12:29PM |
Re: Z-height sensor - inductive? April 28, 2014 01:48PM |
Re: Z-height sensor - inductive? April 28, 2014 01:52PM |
dc42
dmould
Sadly, the only one that RS used to sell that looks good for this application has been discontinued, [uk.rs-online.com]. So I have turned to other suppliers.
Re: Z-height sensor - inductive? April 28, 2014 02:44PM |
Re: Z-height sensor - inductive? April 28, 2014 02:51PM |
dmould
How about [uk.rs-online.com] ?
Whoops - that's 24V (but might work at half power)
But there's
[uk.rs-online.com]
[uk.rs-online.com]
[uk.rs-online.com]
or even
[uk.rs-online.com]
Not that I have any reason to promote RS - just like their next day delivery even when I order in the evening!
Dave
(#106)
Re: Z-height sensor - inductive? April 28, 2014 03:26PM |
Davek0974
As a way of measuring position cheaply and to an accuracy of 0.01mm look to the cheap digital vernier calipers found all over the place, I have 5 in the shop myself, they are only about £8!
They work capacitively and are very simple but plenty accurate.
Re: Z-height sensor - inductive? April 28, 2014 06:06PM |
Re: Z-height sensor - inductive? April 29, 2014 04:06AM |
Re: Z-height sensor - inductive? April 29, 2014 04:18AM |
Re: Z-height sensor - inductive? April 29, 2014 04:34AM |
Re: Z-height sensor - inductive? April 29, 2014 05:10AM |
GregL
Sensor fixed relative to nozzle - Z difference known.
Fire the solenoid to extend the contact tip, and measure the extension.
A bit of arithmetic to determine the exact height of the nozzle.
GregL
How about using the height sensing method of the DamBuster Lancasters - or something similar.
They used angled searchlights on each wing, such that the beams coincided along the centre line of the aircraft when at the exact required height (50 feet I think).
If we can rely on the reflective nature of the surface, then a laser (from a laser pointer perhaps) angled down at, say, 45 degrees to aim near the tip of the hot end.
Detect the position of the reflected beam along the X axis in mm will give the height in mm.
Re: Z-height sensor - inductive? April 29, 2014 05:29AM |
Re: Z-height sensor - inductive? April 29, 2014 06:35AM |
Re: Z-height sensor - inductive? April 29, 2014 06:53AM |
dc42
GregL
That is exactly what I am looking at. I will measure the extension either using the variation in inductance of the solenoid, or with a separate optical sensor. We don't actually need to measure the extension, just to know when the extension is a particular value.
GregL
I thought of something similar. Two LEDs, modulated in antiphase, directed vertically on to the bed such that the spots from them overlap a little. One photoreceptor inside a tube, aimed at the bed at a 45 degree angle. The proportion of light from each LED seen by the photoreceptor will depend on the height. One problem with this arrangement is that we would need to distinguish the reflection from the top of the glass (which is what we want) from the reflection from the bottom of the glass or the heat spreader.
Re: Z-height sensor - inductive? April 29, 2014 07:36AM |
Treth
Use a slotted opto to sense the top part of the plunger. Positioned so it is normally blocked.
Treth
Apply a current to drive the solenoid down just past the opto window such that it has the full beam.
(This will hopefully reduce the force on the tip when in contact with the bed).
Re: Z-height sensor - inductive? April 29, 2014 09:06AM |
Re: Z-height sensor - inductive? April 29, 2014 10:16AM |
Re: Z-height sensor - inductive? April 29, 2014 10:45AM |
Yes, I guessed you had! The spec's and extracted spec's are quite poor, so I appreciate your time and efforts.Quote
dc42
I've gone through a lot of solenoid catalogUes and listings looking for something suitable!
Re: Z-height sensor - inductive? April 29, 2014 10:51AM |
Re: Z-height sensor - inductive? April 29, 2014 03:38PM |
dc42
Interesting! However, a caliper measures the displacement between two parts that are moving past each other. We have a different problem, which is to measure the distance between the nozzle and the bed, while at the same time remaining at least 1mm away from the bed under normal operation even when the head is touching the bed.
Re: Z-height sensor - inductive? April 29, 2014 05:06PM |
Re: Z-height sensor - inductive? April 30, 2014 03:40AM |
Re: Z-height sensor - inductive? April 30, 2014 04:39AM |
Re: Z-height sensor - inductive? April 30, 2014 01:12PM |
Re: Z-height sensor - inductive? April 30, 2014 03:04PM |
Re: Z-height sensor - inductive? April 30, 2014 04:01PM |
dc42
So I'll try the Dambusters-style solution first. It's potentially cheaper than the solenoid solution, given the cost of the tubular solenoid and spring.
Re: Z-height sensor - inductive? April 30, 2014 05:46PM |
Re: Z-height sensor - inductive? April 30, 2014 06:34PM |
