Re: Z-height sensor - inductive? April 30, 2014 08:32PM |
Pointy
dc42
So I'll try the Dambusters-style solution first. It's potentially cheaper than the solenoid solution, given the cost of the tubular solenoid and spring.
Can we have the music with it please?
Les
Re: Z-height sensor - inductive? May 01, 2014 02:52AM |
Re: Z-height sensor - inductive? May 01, 2014 03:22AM |
Re: Z-height sensor - inductive? May 01, 2014 04:42AM |
Treth
@DC42,
If you go back to the push solenoid method then this solenoid is approx 12x11x20mm (coil frame) and a stroke around 5mm PLUS it has the return spring all for £5.10.
[www.kitronik.co.uk]
Re: Z-height sensor - inductive? May 01, 2014 09:07AM |
Re: Z-height sensor - inductive? May 01, 2014 09:55AM |
Re: Z-height sensor - inductive? May 01, 2014 10:00AM |
dc42
Hi Radian,
I am indeed using a different capacitive sensing technique. My prototype uses the Atmel charge transfer technique, which doesn't rely on a constant-current source, but does rely on a reference capacitor (I'm using a temperature-stable one), and requires 2 pins to be connected directly or indirectly to the sense plate (increasing the pin capacitance). I am also using one of my PCBs designed for ultrasonic sensing, which has long traces attached to those pins that run most of the length of the board, hence more stray capacitance.
Would you care to take and post sets of readings taken at (a) bed at room temperature, and (b) bed temperature 70C or higher? With Z=0 calibrated manually before each set of readings, once the bed has reached a stable temperature. From what you have already said, I believe you are getting a lower temperature sensitivity than I am, but I would like to know how much lower.
Also, from the readings you are taking, are you able to calculate the ratio of sense plate capacitance variation to total capacitance?
Re: Z-height sensor - inductive? May 01, 2014 11:25AM |
Re: Z-height sensor - inductive? May 01, 2014 12:30PM |
dc42
..What do Ormerod users want? Maybe everyone is complete satisfied with my IR/ultrasonic boards and doesn't think anything else is needed?..
Re: Z-height sensor - inductive? May 01, 2014 12:41PM |
GregL
..Do I need armour plated glass?
Greg
Re: Z-height sensor - inductive? May 01, 2014 12:49PM |
Re: Z-height sensor - inductive? May 01, 2014 01:29PM |
Re: Z-height sensor - inductive? May 01, 2014 01:35PM |
Re: Z-height sensor - inductive? May 01, 2014 01:55PM |
Re: Z-height sensor - inductive? May 02, 2014 03:41AM |
Re: Z-height sensor - inductive? May 02, 2014 04:20AM |
dc42
Hi Radian,
Re: Z-height sensor - inductive? May 02, 2014 04:44AM |
Re: Z-height sensor - inductive? May 02, 2014 04:54AM |
Can you clarify how the Dambusters version works then, I thought it was the similar but with two beams and you are looking for maximum intensity?Quote
dc42
Treth, the disadvantage of the modulated IR sensor is that it is sensitive to the surface condition of the bed. So it normally requires targets, which means it can't be used for final z calibration at the centre of the bed just before starting a print.
Yes agree re probe, I really meant the fixture to the shaft holding the probe (long screw, or similar as probe) but guess there will still be heat transfer.Quote
dc42
Regarding the rotary probe idea, I prefer the mechanically simpler solution of the linear solenoid. I don't think you could use a printed part for the probe because it would soften and deform after repeated contact with the hot bed.
Re: Z-height sensor - inductive? May 02, 2014 04:59AM |
Re: Z-height sensor - inductive? May 02, 2014 08:00AM |
dc42
Andy, see this post [forums.reprap.org]. An opto sensor would have the same issue with flexing of the plate.
Re: Z-height sensor - inductive? May 02, 2014 10:32AM |
Re: Z-height sensor - inductive? May 02, 2014 10:36AM |
Re: Z-height sensor - inductive? May 03, 2014 02:31PM |
Re: Z-height sensor - inductive? May 03, 2014 03:04PM |
Re: Z-height sensor - inductive? May 04, 2014 06:51PM |
Re: Z-height sensor - inductive? May 08, 2014 03:14AM |
Re: Z-height sensor - inductive? May 08, 2014 07:13PM |
Re: Z-height sensor - inductive? May 09, 2014 04:28PM |
