Control air to the nozzles
April 07, 2014 02:32AM
I wanted to control the air flow to the nozzles to be able to provide cooling to PLA but not to ABS. Kim is working on a similar design for his duct [forums.reprap.org]. The hot air exhaust can either exit through the nozzles or be diverted to a chimney in the fan duct. I have modified the original fan duct to accommodate a plate that can be inserted to block the path to the nozzles. I have added a chimney to the heatsink duct that I originally modified for DC’s new IR sensor. If cooling is required through the nozzles then a stopper is inserted in the chimney and the plate extracted part way to allow air to pass to the nozzles. If cooling is not required then the plate is inserted in the fan duct to block off the nozzles and the stopper is removed from the chimney to allow the warm air to exit at the top.
open | download - fan-duct3.stl (335.3 KB)
open | download - Modified heatsink-duct14.stl (341.9 KB)
open | download - plate.stl (1.4 KB)
open | download - stopper.stl (5.4 KB)
Re: Control air to the nozzles
April 13, 2014 08:23AM
Thanks for this, I decided to give it a go as I change between abs and pla a fair bit and together with DC's fan deflector it works really well! Cheerssmiling smiley
April 13, 2014 09:24AM
bigben
Your welcome
April 13, 2014 10:25AM
Hi John, I like the design, there's a lot of work gone in to it I can see.
I did think about having a valve or plug on the air supply to the nozzles, then decided against it because:-
1) While we can print well, the fit of the valve might not be that good.
2) I didn't want any leaking air to blow on the print...
So.... What I decided was to have the Exhaust air connected all the time and control the amount of air going to the cooling nozzles by metering the amount of air able to go out up the exhaust. ANd then if you wanted to stop ALL the air to have plugs for the nozzles. That way there's no fiddley fitting of valves....
Big Blue uses that idea. I'm just printing the final protype of BB that will allow DC's probe to be fitted to the side...
Once I'm happy that the print is good I hope to release it and may well remove my older designs. Then I'll be designing the plugs, and meter covers for the exhausts, as at the moment people have to use tape. I'm using a Big Blue to print a Big Blue at the moment....cool smiley
The biggest challenge I find is trying to design stuff with the minimum fettling to clean it up ready to use....
Edited 2 time(s). Last edit at 04/13/2014 11:44AM by KimBrown.
April 13, 2014 02:57PM
Kim I will give yours a try as well, won't be for a couple of days though as I have been at pub watching Hull City today and go away to work for a few days in the morning. thanks for all the hard work guys!
April 13, 2014 03:26PM
Sounds like you do a similar job to me then Ben......
Hull City?????? drinking smiley
Hmmmmm well I had hoped to have finished printing the prototype by now, then near the end, it reminded me I had forgotten an unsupported overhang....Grrrrrrr! I missed that...angry smiley Which reminds me.... I must get to designing my granulator and extruder....
Oh well.. Back to the drawing board then.... Nearly finished it.... I enjoy the challenge... Just wish I wasn't so impatient waiting for the print to finish.... I have some other stuff waiting in the wings now to be printed....
January 29, 2015 07:19AM
Hi John
Great design, will this work on the Ormerod 2? Looking at the STL they are not too different
Thanks
James
January 29, 2015 02:14PM
jamesf
James
To be honest I don't realy know, I don't have access to an Omerod 2 and dont know the differences. But I would be happy to have a look at the STLs and modify them if necessary.
I have modified the design slightly to increase the width of a couple of walls. I can repost the the stls if there is any interest
Let me know.
Regards
John
January 29, 2015 03:12PM
Hi John
here is a link to Ormerod 2 documentation. There are minor differences but I think it should work, unless I'm missing some small detail.
[reprappro.com]
thanks
James
January 29, 2015 06:09PM
Hi
Have you seen the thread where i posted my venting mod. It uses a flap and a 6 cm fan.
I would be really interested if you could print a small object like this:
haus2.stl
haus2.scad
I found it to be a good benchmark for nozzle cooling. The stock cooling failed for me completly.
Just print one house so that there is no much time for cooling. If its not sufficient its directly
visible on the roof. Besides that object is so small that not much time/plastic is wasted with printing
plus you can use it for a board game of your choice :-).
Can you also print ABS with these mods?
Best regards
Tim
January 30, 2015 12:50AM
Hi Tim,
Yes I saw your thread. I am looking for a duct that will fit with DC43's IR sensor which I am waiting for. Does yours support that?
I should have some printer time this weekend. Will try your house print
Cheers
James
January 30, 2015 06:05AM
Hi James
jamesf
The latest version i failed to upload is adapted to dc42's ir sensors. Its a little crowded and the vent channel could be a little larger but
with first test prints i am pretty happy.
jamesf
Unfortunatly i am traveling right now (fosdem.org) and i have no connection to my desktop at home, so i am sorry that i can make it only
available next week.
Best regards
Tim
January 30, 2015 06:08AM
Hi Tim
No problem, not in a hurry
February 02, 2015 03:52PM
Hi James
I just uploaded the fanduct parts to my repository:ormerod parts.
Its still not as good as the my non dc52 for small PLA parts. For ABS printing you must have the backwash protector (thanks dc42 for the hint btw.). So i guess this wont be my last version of this fanduct but still from my limited printing experience, especially with ABS i think its a already a good compromise and better than the stock venting.
Tim
