Ormerod DUET problem April 10, 2014 11:57PM |
Re: Ormerod DUET problem April 11, 2014 02:13PM |
Re: Ormerod DUET problem April 11, 2014 03:29PM |
Re: Ormerod DUET problem April 12, 2014 04:55AM |
dmould
How is the Duet powered - do you have JP9 installed and powering from the 12V, or is it powered from the USB?
If you are powering from the USB, it is possible that your laptop USB socket cannot supply quite enough power, and the Duet is getting too low a voltage. If that is the case, either power the Duet from the 12V supply by fitting the jumper, or connect the Duet to a powered USB hub and connect the laptop to that hub instead of direct to the Duet.
Dave
(#106)
dc42
Are any of the components on the Duet board getting hot?
