Duet ATX power control April 15, 2014 11:10AM |
Re: Duet ATX power control April 15, 2014 12:25PM |
Re: Duet ATX power control April 15, 2014 05:07PM |
bobtidey
Apart from adding low level support for this, the power on strategy would need to be worked out.
Re: Duet ATX power control April 15, 2014 05:26PM |
Re: Duet ATX power control April 15, 2014 07:07PM |
Re: Duet ATX power control April 16, 2014 03:12AM |
Re: Duet ATX power control April 16, 2014 03:58AM |
Re: Duet ATX power control April 16, 2014 05:21AM |
Re: Duet ATX power control April 16, 2014 05:50AM |
Re: Duet ATX power control April 16, 2014 09:03AM |
Re: Duet ATX power control April 21, 2014 06:05PM |
Re: Duet ATX power control April 21, 2014 06:24PM |
Re: Duet ATX power control April 21, 2014 06:41PM |
Re: Duet ATX power control April 22, 2014 10:27AM |
Re: Duet ATX power control April 22, 2014 11:27AM |
Pointy
I am assuming that there is a transistor that just grounds the white wire to switch on the ATX PSU? I have one of these coming for my 30a PSU, but I am thinking it wants a high signal to switch it on. I guess I'll find out when it arrives.
Re: Duet ATX power control April 22, 2014 11:33AM |
Re: Duet ATX power control April 22, 2014 11:52AM |
Re: Duet ATX power control April 22, 2014 12:42PM |
Re: Duet ATX power control April 22, 2014 12:43PM |
dc42
Pointy
Yes, the output is an open drain small signal mosfet, that grounds the white wire to switch the power on.
If you will be switching the 12V supply, where are you going to get the 5V supply for the Duet from - a separate voltage regulator?
If your main reason for switching the 12V supply is to turn the stepper motors off, that could be accomplished more easily in the firmware. Perhaps I should make M80/M81 turn the stepper current on/off as well as controlling the ATX power supply signal.
Re: Duet ATX power control April 22, 2014 12:51PM |
dmould
A secondary advantage is that it stops the fan running - though that could of course be connected to the Duet and controlled via firmware separately.
Re: Duet ATX power control April 22, 2014 02:22PM |
dmould
5V could probably be obtained from the standby (always on) 5V that ATX PSU's have available.
Re: Duet ATX power control April 22, 2014 04:02PM |
dc42
If you will be switching the 12V supply, where are you going to get the 5V supply for the Duet from - a separate voltage regulator?.
dc42
Re: Duet ATX power control April 22, 2014 05:51PM |
Pointy
I know you have put some stuff in the new firmware, but what happens if the chip locks? I presume the firmware stops running, so would all the heaters stay on, could motors continue?
Re: Duet ATX power control October 09, 2015 01:15PM |
