Press print and wait forever April 16, 2014 05:21AM |
Re: Press print and wait forever April 16, 2014 05:57AM |
Re: Press print and wait forever April 16, 2014 06:19AM |
Re: Press print and wait forever April 16, 2014 06:47AM |
Re: Press print and wait forever April 16, 2014 07:21AM |
Re: Press print and wait forever April 16, 2014 08:28AM |
Re: Press print and wait forever April 16, 2014 08:47AM |
Re: Press print and wait forever April 16, 2014 09:58AM |
Unfortunately, if using Pronterface you cannot check the temperatures while the Duet is hanging on a M116 command - the temperatures don't get reported during the waiting period. I've not used the web interface, so don't know if that is any different.Quote
dc42
I suggest you:
2. Also when using start code 1, watch the temperatures when it is waiting forever, to see what values they reach.
Re: Press print and wait forever April 16, 2014 10:39AM |
Re: Press print and wait forever April 16, 2014 11:26AM |
Re: Press print and wait forever April 16, 2014 12:06PM |
Re: Press print and wait forever April 16, 2014 01:14PM |
dc42
Dave, if you've not used Matt's web interface, then I suggest you take a look at it. It is now far superior to Pronterface. And yes it does continue to report the temperatures (as well as the head position and the z-probe value) while executing M116.
Re: Press print and wait forever April 16, 2014 01:21PM |
Re: Press print and wait forever April 16, 2014 01:37PM |
Re: Press print and wait forever April 17, 2014 07:38AM |
auser
dmould, to start you could use the webif as you do pronterface: just connect it directly with an ethernet lead modern day pc's generally do auto-x-over. This way you could leave th ormerod set to the company ip an use a direct cable @home setting the pc to a suitable ip.
The webif is really much nicer plus unplugging never caused any trouble...
Re: Press print and wait forever April 17, 2014 07:58AM |
dc42
Dave, my latest firmware and my variant on Matt's web interface serves all the files from the Duet, so you won't need a local web server. And the web interface really is much nicer than Pronterface to use!
In principle, the web server could be modified to get its IP address via DHCP, however I'm not sure that would help because you would then need to find out what IP address has been assigned to it.
Re: Press print and wait forever April 17, 2014 09:03AM |
Re: Press print and wait forever April 17, 2014 09:55AM |
I actually often disconnect my laptop from the printer after I have seen that the first 1 or 2 layer(s) stick, return to the light (from the cellar) and work on the laptop (including internet). Re-Plugging the printer is possible @ any time.Quote
dmould
If I did that, I would not be able to use the PC on the Internet while I am printing!Quote
auser
.. you could use the webif as you do pronterface: just connect it directly ...
Re: Press print and wait forever April 17, 2014 10:11AM |
Re: Press print and wait forever April 17, 2014 10:46AM |
Re: Press print and wait forever April 17, 2014 11:05AM |
Re: Press print and wait forever April 17, 2014 11:13AM |
Re: Press print and wait forever April 17, 2014 01:39PM |
Re: Press print and wait forever April 17, 2014 03:06PM |
Re: Press print and wait forever April 17, 2014 04:36PM |
Re: Press print and wait forever April 17, 2014 05:27PM |
Re: Press print and wait forever April 17, 2014 05:42PM |
Re: Press print and wait forever April 17, 2014 05:49PM |
Re: Press print and wait forever April 18, 2014 06:16AM |
Re: Press print and wait forever April 18, 2014 06:29AM |
