Where to get connectors
Posted by alanbattersby
April 17, 2014 04:47PM
Could someone who is knowledgeable about electronics please tell me where I can get the connectors that push onto the Duet board?
Are they Molex connectors? I have not broken any of mine I just want to add try using a spare output to play around.
Thanks
Alan
Edited 1 time(s). Last edit at 04/17/2014 04:48PM by alanbattersby.
Re: Where to get connectors
April 17, 2014 05:11PM
For my sensor board kit, to connect to the pins on the Duet I use these crimp receptacles [uk.farnell.com] and these 2-way shells [uk.farnell.com]. If you only want to connect one or two wires, then Maplin sells some suitable connectors in packs of about 8 or 10.
Edited 3 time(s). Last edit at 04/17/2014 05:14PM by dc42.
April 17, 2014 05:38PM
Thanks dc42,
I am thinking of buying a duet board to play around with and connect to some steppers. I fancy making a delta printer as I like the movement of the 3 arms.
Alan
April 18, 2014 04:13AM
You can get them from proto-pic, they also do some of the Sparkfun stuff in the UK. I have used them before and the service is good.
Regards,
Les
April 19, 2014 05:54AM
Search for 'Dupont head' on eBay - they are next to free from China, and unless you want gold-plated quality I think they are just as good for experimentation.
/Allan
