Ormerod Duet Board Failure April 19, 2014 03:40PM |
Re: Ormerod Duet Board Failure April 19, 2014 05:12PM |
Re: Ormerod Duet Board Failure April 21, 2014 01:42AM |
Re: Ormerod Duet Board Failure April 21, 2014 03:29AM |
Re: Ormerod Duet Board Failure April 21, 2014 03:50AM |
PhilipTheMobster
Hello DC,
I removed all connections still the same result. USB led turns on, but further nothing happens. Can we conclude the board is dead?
Kind regards,
Philip
Re: Ormerod Duet Board Failure April 21, 2014 05:37AM |
Re: Ormerod Duet Board Failure April 21, 2014 05:55AM |
Re: Ormerod Duet Board Failure April 21, 2014 07:23AM |
Re: Ormerod Duet Board Failure April 21, 2014 08:15AM |
dc42
It sounds to me that something is getting hot and stopping working, then needs to cool down again. I suggest you check whether any other components are getting hot, e.g. the linear regulator (it's the chip with 2 capacitors and an inductor next to it, labelled LM1117MP-3.3). There have been a couple of reports on this forum of what looks like internal shorts on boards, and it is possible that you have a temperature-sensitive internal short.
Also, if you connect the board to the PC with USB power only (no 12V power), does it still stop communicating after a while? What if you disconnect all the steppers and heaters, and apply 12V power?
Re: Ormerod Duet Board Failure April 21, 2014 08:25AM |
Re: Ormerod Duet Board Failure April 21, 2014 09:09AM |
KimBrown
I had problems with the 57za/zb firmware.. I'm back to 57y now, which is ashame as I liked the quick start and long file names.
Bugs are real little critters that sneek in to the best of things, and can be a real pain to track down. I'm sure DC will work it out...
Re: Ormerod Duet Board Failure April 21, 2014 01:46PM |
Re: Ormerod Duet Board Failure April 21, 2014 03:09PM |
Re: Ormerod Duet Board Failure April 21, 2014 03:17PM |
Re: Ormerod Duet Board Failure April 22, 2014 04:33PM |
Re: Ormerod Duet Board Failure April 23, 2014 08:49AM |
Re: Ormerod Duet Board Failure April 28, 2014 03:25AM |
Re: Ormerod Duet Board Failure April 28, 2014 06:05AM |
Re: Ormerod Duet Board Failure April 28, 2014 07:15AM |
Re: Ormerod Duet Board Failure April 28, 2014 07:21AM |
Re: Ormerod Duet Board Failure April 28, 2014 07:22AM |
Re: Ormerod Duet Board Failure April 28, 2014 09:38AM |
Re: Ormerod Duet Board Failure May 06, 2014 05:40PM |
Re: Ormerod Duet Board Failure May 06, 2014 07:34PM |
Re: Ormerod Duet Board Failure May 10, 2014 04:44PM |
Re: Ormerod Duet Board Failure May 11, 2014 05:02AM |
Re: Ormerod Duet Board Failure May 11, 2014 05:56AM |
Re: Ormerod Duet Board Failure May 11, 2014 09:13AM |
Re: Ormerod Duet Board Failure May 11, 2014 11:17AM |
Re: Ormerod Duet Board Failure May 11, 2014 11:53AM |
