Thinking of trying a water cooled hot end
Posted by JMC
JMC
April 21, 2014 06:57AM
Just wondering if anyone has done this on an Ormerod given that their are many other repraps out there using this method of hot end cooling.
Have been thinking of replacing the aluminum piece that the hot end attaches to for a larger one with channels drilled through for water.
Re: Thinking of trying a water cooled hot end
April 21, 2014 07:03AM
I'll be doing just that while I'm home later in the week.... Been looking around for a nice little 12V pump....
JMC
April 21, 2014 07:23AM
Thort i might use a low voltage fountan pump for the water. Have noticed you have added cooling ducts to the bottom of big blue for bridging, what were your thorts on cooling the print with a water cooled hot end.
JMC
April 21, 2014 07:46AM
At the moment we have no air blowing from the hot end fan on to the print and insted use a normal fan to prevent warping after the first two layers. But i was thinking of using a little blower fan to provide cooling only at the point of extrusion.
open | download - WP_000246.jpg (381.1 KB)
April 21, 2014 08:06AM
I was going to add a mini fan with two ducts blowing down either side, like Big Blue has... I have a nice little 20mm fan waiting...
I would have thought that the Big Fan you have there would cause you warping problems....
Is the room very warm? Wish I could see a closer picture of the cooling rig,
My plan was to make a water cooled block out of Marine Grade Ally, that fell in to the boot of my
car.....confused smiley The nice thing about Ally, is it didn't make a bang when it landed.....spinning smiley sticking its tongue out
JMC
April 21, 2014 08:29AM
Will take a better picture with lights off. Am printing the test pice from the "Printing artefacts" post but forgot to turnoff the min layer time so print keeps stopping.
JMC
April 21, 2014 09:21AM
Room is about 25C not warm for the AU but we havent used the fan for any large flat prints yet so may have to cross that brige when we get to it :-) Like most Ormerod users theres been a lot of trial and error over the last 4 months. The current hotend rig is just a kapton tape mockup using a blower from an imac and a small heat sink from the bottom of a draw. There air is forced doun then around and out the top again in a U shape there is a small baffle running from the center top to half way doun the inside to enshour the air circulates around the full area of the heat sink. If the water cooled hot end becomes a non starter then ill probbly print out a proppre cover for this one.
open | download - WP_000253.jpg (353 KB)
open | download - WP_000250.jpg (390.4 KB)
April 22, 2014 09:25AM
You might be able to adapt a CPU water cooled heatsink. I'm not however convinced it will provide any improvement to the print quality - what advantages do you believe water cooling will provide above that provided by fan modifications that keep unwanted fan wash away from the bede??
Dave
(#106)
April 22, 2014 09:41AM
Hi Dave, one big thing will be to have more space around the HotEnd to see what's going on...
Water is a great medium for cooling, as it absorbs so much heat, so the flow doesn't have to be that much.
I'm even wondering if the outlet could be a water jacket for the filament to help raise it's temperature a little to reduce the work
the heater has to do. Hopefully it will be quieter that the fan/s as well. If it works out we can reduce the mass (weight) in that area, then faster speeds are also possible... I think there's allot to be gained by it.. I have my eye on my young ladies fish tank pump which I think I can find a better home for.... winking smiley
As for cooling the water, I think a jug of water on it's own would probide enough cooling for 5 or 6 hrs if not all day.
I also hope to start work on a twin Extruder head this coming week... The design is in my head, just got to progress it, but can't while at work...
My milling machine won't fit in my luggage....
April 22, 2014 09:52AM
Hi Guys
You might want to look at the e3d Kraken:
Blog on printing with Duet and E3D Kraken
e3d Kraken
Its a water cooled monster but the theory could be scaled down to a single extruder. On the other hand it provides for future expansion.
I use a small pump that used to drive a pet water fountain - you dont need a very high flow rate to keep it cool, even with all 4 nozzles hot.
Cheers
Tony
DuetWifi.: advanced 3d printing electronics
April 22, 2014 01:33PM
could something like this be used with the existing block? [www.ebay.co.uk]
April 23, 2014 07:51AM
bigben
Cheaper & more details here: [www.aquatuning.co.uk]
Quote:
Technical details:
Dimensions: 17x14x58mm
Weight: 113g
Material: Copper. nickel plated
Thread size: G1/4"
Hole distance: 61-96mm
It is a tad too big, though I guess it would be possible to mount it against the aluminium cooling block in a position that doesn't foul anything. I expect you'd also want the water tubes to be thinner than 1/4" to provide the required degree of flex. I think I would probably make a block myself. Not that difficult - the very simplest way would be to start with a length of square brass stock that matches the size of the aluminium cooling block. Drill a hole through it longitudinally and braze a couple of standard small brass pipe nipples into the hole at either end. This could then be clamped to the aluminium cooling block, perhaps with a couple of strong spring clips.
Dave
(#106)
Dave
(#106)
April 23, 2014 12:57PM
Since you wouldn't really need the heatsink and cooling fan for the hotend, you could have a "cooling block" that is a fair bit larger than just the standard block.
April 23, 2014 01:39PM
Is there any point in using a water-cooled hot end when there is just one extruder?
April 23, 2014 02:24PM
Well, one thing would be to make the printer quieter (as the hotend cooling fan is by far the most noisy thing on the printer). Also because it's cool and challenging. But, if someone is making one, might as well do one with room for 3 or so nozzles.
April 23, 2014 02:30PM
which is what the Kraken is...
April 23, 2014 02:37PM
jstck
Sure, but a larger block has no advantages, and has the disadvantage of adding a fair bit of additional weight (water is heavy).
Dave
(#106)
April 23, 2014 03:22PM
jstck
If noise reduction is the main goal, do as many of us have done and just fit a quieter fan - they are very cheap. My replacement hotend fan (RS part # 758-8207) is so quiet I cannot hear it at all over the PSU fan (and I have a pretty quiet LED PSU). It takes 5 minutes to change ...
If you want to cool the filament, then you'll have to fit a separate fan near the hotend anyway. And you may well find you require a radiator and fan to keep the water acceptably cool over long prints - and find a safe place to mount the water pump and water reservoir/radiator. Water has a high specific heat so a large mass will heat very slowly - but I have done prints that took 12 hours to complete. No matter how much water is in the system there must be the same amount of heat getting out as is being put in at an acceptably low equilibrium temperature, and relying on standard plastic pipework to shed enough heat is almost certainly overly optimistic - especially at ABS temperatures. If that were the case, the existing heatsink would be sufficient without a fan, because I'm quite sure it can shed more heat in free air than a meter or so of plastic pipe can achieve. Water only transports the heat so you can get rid of it elsewhere, it doesn't remove the heat by itself unless you have a fish-tank sized reservoir or are feeding water from a tap and expelling it down a drain.
All in all I am far from convinced that it will result in any appreciable improvement, and may well cause unforeseen problems.
Dave
(#106)
April 23, 2014 03:32PM
Dave
All valid points, the main advantage in my experience is the ability to reduce the size of hotend for multiple extruder setups. The water cooling is very efficient in comparison to air allowing for a relatively small cooling block with a number of closely packed nozzles. It is probably over complicating things for a "standard" single extruder setup.
Cheers
Tony
April 23, 2014 04:40PM
T3P3
Hi Guys
Tony
Hi Tony,
the monster is fully compatible with Ormerod?.... I love it
Dario
Ormerod 187
Firmware Electronics: Duet 0.6
Firmware Version:1.18.1 (2017-04-07)
Web Interface Version:1.15a
Slic3r 1.2.9a and Simplify3D 4.0.0
[www.dropbox.com]
April 23, 2014 05:06PM
Hi Dario
It is supported by the Duet, but clearly you need the Duex4 expansion board to run more than one extruder. Like I did for the Mendel90 the hotend mount would need some modification. My Multi Extruder branch of RepRap firmware works with it already smiling smiley
Cheers
Tony
JMC
April 24, 2014 05:12AM
For a single hot end i think weight might be a problem given the boom like configeration of the ormerod. Im curently trying to cut down a heat pipe from an old laptop but its a bit heavy. I think it might be better to replace the aluminum mounting block rather than just stick somthing on in place of the current heat sink.
As for why ? i like to be able to see what im printing without having to peer under the fan and cooling vents.
open | download - WP_000264.jpg (317.4 KB)
April 24, 2014 06:05AM
JMC
Why not simply take a hacksaw to the cooling vents as I have done? Then block the air channel to the vents and drill a hole in the top of the fan block for the air to get out instead. Sure, there is still the fan block present, but you have plenty of clearance to print up close to the clips etc., and I get a very reasonable view of the print. If I wanted a slightly better view it would be trivial to design a different fan block so that nothing extends below the bottom of the cooling block. (Which I intend to do as soon as I can source a round tooit, as well as making a separate controllable fan for cooling bridges),
Dave
(#106)
JMC
April 24, 2014 06:24AM
dmould
JMC
Dave
(#106)
:-) done that but want to go further.
April 24, 2014 07:16AM
JMC
dmould
JMC
Dave
(#106)
Good heavens! Not sure you need quite that much airflow!
As an idle musing, I wonder whether a Peltier cooler would pump sufficient heat away from the cool block? We have high current 12V DC readily available, and it would do away with complex plumbing.
Dave
(#106)
April 24, 2014 07:27AM
dmould
A Peltier just moves heat from one side to the other, adding more of its own - so giving you more heat to get rid of with a heatsink and fan. It's not useful unless you want to cool something to below room temperature, or at least below what you can achieve with a heatsink and fan.
Edited 1 time(s). Last edit at 04/24/2014 07:27AM by dc42.
JMC
May 10, 2014 10:07AM
have just finished the water cooled heat sink. I was hoping to test it tonight but will have to wait till the shops open tomorro so i can get a pump and some more pipe. I ended up keeping the original ali block becouse i did not want to dismantle the hot end untill i have some spare bits (incase i stuff somthing) but im hoping to be able to replace the whole thing eventualy make room for multiple heads.
open | download - WP_000323.jpg (363.6 KB)
open | download - WP_000330.jpg (464.1 KB)
May 10, 2014 02:02PM
Dunno if this might work in that application
Halfords windscreen washer pump
regards
Andy
Ormerod #318
www.zoomworks.org - Free and Open Source Stuff smiling smiley
JMC
May 11, 2014 08:50AM
Have just completed my first water cooled print.
The setup needs some improvment but the print quality is consistant with my previos blower heat sink. The biggest problem will most likely be keeping the water cool over a very long print, my curent setup uses a beer mug with some ice in it whitch may have been too effective as i noticed condensation forming on the heatsink and the hot end tempricher wavering slightly. My next step will be to setup some sort of cooling coill and if possible sorcing a non submercible pump so i can make the system more contained and not have a jug of water on my desk.
open | download - WP_000345.jpg (482.6 KB)
May 11, 2014 09:47AM
It would be priceless if you made it look like this grinning smiley
