anyone redesign the z nut trap? April 26, 2014 06:56AM |
Re: anyone redesign the z nut trap? April 26, 2014 08:49AM |
Re: anyone redesign the z nut trap? April 26, 2014 09:12AM |
Re: anyone redesign the z nut trap? April 26, 2014 10:15AM |
Re: anyone redesign the z nut trap? April 26, 2014 04:10PM |
Re: anyone redesign the z nut trap? April 26, 2014 07:49PM |
Re: anyone redesign the z nut trap? April 27, 2014 05:52AM |
Re: anyone redesign the z nut trap? April 27, 2014 09:27AM |
Re: anyone redesign the z nut trap? April 27, 2014 10:20AM |
Re: anyone redesign the z nut trap? April 27, 2014 11:08AM |
Re: anyone redesign the z nut trap? May 01, 2014 02:50PM |
Re: anyone redesign the z nut trap? May 02, 2014 03:45PM |
Re: anyone redesign the z nut trap? May 02, 2014 07:00PM |
Re: anyone redesign the z nut trap? May 02, 2014 07:49PM |
Re: anyone redesign the z nut trap? May 02, 2014 11:02PM |
Re: anyone redesign the z nut trap? May 03, 2014 03:59AM |
Re: anyone redesign the z nut trap? May 11, 2014 05:32PM |
Re: anyone redesign the z nut trap? May 11, 2014 05:51PM |
Re: anyone redesign the z nut trap? May 11, 2014 05:56PM |
Re: anyone redesign the z nut trap? May 11, 2014 06:02PM |
Re: anyone redesign the z nut trap? May 11, 2014 07:01PM |
Re: anyone redesign the z nut trap? May 11, 2014 08:56PM |
Re: anyone redesign the z nut trap? May 12, 2014 01:59AM |
KimBrown
...So now every time I setup the machine, I check it's square. You can push it back square very easily, you don't have to slacken screws....
Re: anyone redesign the z nut trap? May 12, 2014 03:12AM |
Re: anyone redesign the z nut trap? May 12, 2014 03:49AM |
KimBrown
And the Z-axis is just to easy to use as a handle to get it in and out of it's box. Unfortunately sometimes that's enough to move it. So now every time I setup the machine, I check it's square. You can push it back square very easily, you don't have to slacken screws....
Re: anyone redesign the z nut trap? May 12, 2014 04:02AM |
Re: anyone redesign the z nut trap? May 12, 2014 04:22AM |
ormerod168
Did you use 10mm for the z-corner-bracket?, if not the 12mm screw will bottom out on and be of no support to the left side of the aluminum extrusion
ELLO POLLY! Testing! Testing! Testing! Testing! - anyone out there?
LOL!
Erik
Re: anyone redesign the z nut trap? May 12, 2014 04:36AM |
