Ormerod hotend parts dimensions
Posted by madmob
April 29, 2014 05:15AM
HI All
Any idea where to find the actual drawings for the hotend parts, as the ones (Nozzel) in the software package is not the correct file.
Any help in this regard would be greatly appreciated.
Thanks
Madmob
[Madmob Consulting:] Promoting 3D printing down South
Re: Ormerod hotend parts dimensions
April 29, 2014 05:59AM
Hi Madmob
Sorry, there are a few parts like this that we need to sort out. The Bowden tube unions, one-piece nozzle and tapered nut are common between Ormerod, Mendel and Huxley kits; the files in this folder are the correct drawings: [github.com]
Except that the 'hobbed insert' in there is for the Mendel. The Ormerod hobbed insert is only available as part of the STEP file, or as a SolidWork part; both are in the Ormerod github repo: [github.com]
Ian
RepRapPro tech support
April 29, 2014 06:59AM
Hi Ian, do you have the drawings for the aluminium heater block as well?
Antonio
April 29, 2014 09:40AM
Hi Ian
Thanks alot for the link, now only need those two alu blocks...
Manufacturing here in SA will work out cheaper than getting from the UK...
Thanks
Madmob
April 29, 2014 11:14AM
The aluminium heater block and aluminium cooling/heatsink block are also the same as the Mendel/Huxley version - the whole hot end is shared between them, though the Ormerod has the fan and nozzle duct, and a bigger fan.
However, we've managed to hide them as well, unintentionally... it's just we haven't needed to update them for a loooooong time.
DXF and pdf files for these (heater-block and heatsink-block) are in [github.com]
The SolidWorks versions in the Ormerod 'sw' folder are all development versions, so aren't quite what is being shipped. I'll try to get the right ones put in, but I'm not sure if we'll output dxf versions of them. I'll try and get the files above collected as pdfs, at least, into a folder called 'pdf' in the Ormerod repository.
Ian
April 29, 2014 11:19AM
Hi Ian
Much appreciated.
Madmob
April 30, 2014 06:20AM
Hi Guys
As stated before, I am trying to get replacment parts manufactured here in SA to save cost..
Question, and I think it be a stupid one but this is my first dance with the laser cutters....
The DXF files, how do they scale, size wise. I sent the some of the DXF files to a Laser Cutting service, but got the reply that my files are not scaled properly.
Some come out as meters long...
Any idea, please....
Thanks
Madmob
April 30, 2014 06:55AM
I measured mine quickly to use it as a guide for designing Big Blue.
April 30, 2014 07:12AM
Hi Kim
Thanks for the above...
Now I just need to get the laser cutting done.... what a pain
Thanks
Madmob
April 30, 2014 08:27AM
I think all the dxf files are scaled in mm. What are you opening them in? Inkscape is an open source vector editing program, that can open dxf files, so you can check.
Ian
April 30, 2014 08:42AM
Hi Ian
Currently using OpenScad...
The laser cutters are using Corel Draw thou... seems this is where things move sideways.
Will look at Inkscape as suggested.
Thanks
Madmob
