Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 06:04AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 06:07AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 06:46AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 08:31AM |
appjaws1
Thanks Dave,
I can see that in the gcode, the last layer height is Z19.920, so does that mean that the last layer is 0.08 high? or is the object 0.16mm higher than specified?
appjaws1
If I had a layer height of 0.25mm then presumably the height would be correct with 80 layers and all layers would have the same height.
I read somewhere in this forum some time ago that the reason for a height of 0.24 was something to do with the Z motor steps, 0.24 ensures whole number step movements.
What is your expert opinion, would 0.25 and whole layers be preferable to 0.24 with whole number steps?
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 08:32AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 08:59AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 09:16AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 10:08AM |
appjaws1
Even more confused now.
using a layer height of 0.25, the height was reported as designed i.e.20mm, 84 layers, filament 3903, that is 39mm more than when layer height was 0.24.
When the print had finished the message strip said 99% Completed, Layer 83 of 84, Filament 3902.937 of 3903mm
I now have 2 parts which should be the same.
the actual height of the 0.24 layer height part is 19.83mm
the actual height of the 0.25 layer height part is 20.24mm
The only slic3r setting that was changed was the layer height.
So I don't know which layer height to use now
Any thoughts???
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 11:04AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 11:57AM |
appjaws1
Just need to sort out why my top layer is full of holes and not a nice smooth finish.
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 12:50PM |
appjaws1
Dave,
Yes I have the first layer set the same as all other layers.
I've just finished a print at 0.2mm layer height and the actual finished height is spot on to the design height.
Paul
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 06:33PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 01, 2014 08:37PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 04:21AM |
Yes.Quote
dc42
1. Did you extract all the web files and subdirectories into the www folder of the SD card? The file structure within www on the SD card should be the same as the file structure within [github.com].
Everything was closed.Quote
dc42
2. After flashing the firmware and/or updating the web interface on the SD card, if there was previously a browser session connected to the Duet then this can mess up the connection. I sometimes find I need to close the browser tab that was connected to the Duet before the firmware update, reset the Duet, then open a new browser tab and connect again.
Yap, the connection is good.Quote
dc42
3. Do you have a good network connection between the PC and the Duet? This version of the web software loads all the web files from the Duet (instead of just reprap.htm from the Duet and the rest from the internet or a local web server on the PC), so it is more important to have a good network connection.
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 05:21AM |
Sardi
EDIT:
Out of the blue - I wanted to upload a file over Web Interface to SD card, but it goes directly to print - the upload window opens and the upload bar progresses as the print goes on.
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 05:33AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 06:37AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 06:44AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 06:58AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 07:20AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 07:39AM |
Network connection error, code -11 Network ConnectionError: didn't find hskeep showing in Pronterface console every second when the Web interface is activated.
SD printing.keeps showing up in Pronterface console every second while printing from SD card. Also it doesnt show how much filament will be used, nor how long will the print take time.
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 09:08AM |
Sardi
- These lines
- The Pronterface does not register heat changes while heating the head and the bed for printing. Its like it freezes and continues to display temperature once the top temperature is reached.
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 09:26AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 10:25AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 10:30AM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 10:37AM |
dc42
- These lines
That is not right - they may occasionally pop up when establishing or remaking the connection, but should not keep occurring. What happens if you close that browser tab (any any others that are connected to the Duet), reset the Duet, connect Pronterface, and web connect again in a new browser tab - do those messages still keep showing?
dc42
I'm not sure that monitoring temperatures in Pronterface works during SD printing or web printing - maybe someone can confirm? Do you have the "Monitor" box checked? Are the temperatures displayed in the web interface being updated?
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 10:47AM |
dc42
...I'm not sure that monitoring temperatures in Pronterface works during SD printing or web printing - maybe someone can confirm? Do you have the "Monitor" box checked? ..
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 11:05AM |
ormerod168
dc42
In Pronterface, with any firmware I have used, monitoring of temperatures stops the moment I start a SD print, it doesn't bother me, to monitor anything you have lost control over don't make any sense
And fair enough, If I wanted to change any ingredients (slicing) I should have done so before putting the cake in the oven (send to print)
Erik
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 12:04PM |
Re: Updated firmware 0.58d-dc42 and web interface 0.73 May 02, 2014 12:33PM |
KimBrown
Sorry to say I tried 58e....
The printer was awfull.... Jerking around trying to print....
I've gone back to 57y again.....
