deeper duet enclosure May 04, 2014 07:41PM |
Re: deeper duet enclosure May 05, 2014 04:12AM |
Re: deeper duet enclosure May 05, 2014 04:24AM |
Re: deeper duet enclosure May 05, 2014 05:02AM |
Re: deeper duet enclosure May 05, 2014 05:23AM |
appjaws1
The solid base option does not report any errors.
The open back option reports 8 errors which are auto repaired.
These errors are to do with the 8 holes for screw fixing, I think I didn't extend them beyond the face enough, although they looked complete on the rendering, however I think it will print correctly.
I can't post the OpenSCAD files because I am on limited bandwidth on mobile data until the end of May, but I will gladly post them after that.
Paul
Re: deeper duet enclosure May 05, 2014 05:29AM |
appjaws1
Re: deeper duet enclosure May 05, 2014 05:49AM |
Re: deeper duet enclosure May 05, 2014 12:47PM |
Re: deeper duet enclosure May 06, 2014 04:07AM |
Re: deeper duet enclosure May 06, 2014 06:15AM |
Re: deeper duet enclosure May 06, 2014 08:33AM |
Re: deeper duet enclosure May 06, 2014 09:18AM |
Re: deeper duet enclosure May 06, 2014 06:18PM |
Re: deeper duet enclosure May 07, 2014 02:44AM |
Re: deeper duet enclosure May 07, 2014 03:23AM |
Re: deeper duet enclosure May 07, 2014 03:32AM |
Sardi
Pointy
There is a very good GCode simulator here, which should allow to spot any major errors without wasting time & material.
Regards,
Les
Look cool, but how does one add this to slic3r?
Antonio
Re: deeper duet enclosure May 07, 2014 03:33AM |
Sardi
Re: deeper duet enclosure May 07, 2014 05:53AM |
Re: deeper duet enclosure May 07, 2014 09:23AM |
Sardi
Mate, its a no go. You should really try to print this yourself to see what happens. Now it starts ok, but in the first layer, when it comes to the bottom 4 holes, the filament just gets completely wraped up in a small ball of filament, draging and sticking everything arround with it as it goes on. Unfortunately there is no photo this time because there is nothing to take a photo of, I had to throw away most of the filament as I stopped the process.
I tried 4 times to print your casing, once it even got stuck arround the first hole, and filled it up with filament and the same thing happened as mentioned above. Also I have changed the bed temperature, to eliminate the bed as not being sticky enough, but that was also not the case. Every time I start with the spot clean nozzle, and finish with the nozzle being covered in filament.
Every time after the try I started printing something of mine and have re checked the Z probe, just to be sure that my settings are working, and everything seems ok by me.
Wish I could help you more, but I dont know anything about OpenSCAD nor why this happens during print.
Re: deeper duet enclosure May 07, 2014 08:07PM |
Re: deeper duet enclosure May 07, 2014 10:06PM |
Re: deeper duet enclosure May 14, 2014 04:19PM |
Re: deeper duet enclosure May 15, 2014 03:35AM |
Re: deeper duet enclosure May 15, 2014 06:59PM |
Re: deeper duet enclosure May 16, 2014 04:50AM |
Re: deeper duet enclosure May 16, 2014 07:44AM |
