Printing Problems May 08, 2014 12:33AM |
Re: Printing Problems May 08, 2014 01:32AM |
Re: Printing Problems May 08, 2014 02:17AM |
Re: Printing Problems May 08, 2014 02:44AM |
robbycar
Was also wondering why it would not be possible to install a small dial indicator attached to the X axis arm and use it for setting bed compensation. Jog Z down until dial reads zero, then do a get pos and use this value for compensation.
...But I have ordered the alum bed plate and I do plan on making the bed level anyway.
Rob.
Re: Printing Problems May 08, 2014 02:49AM |
Re: Printing Problems May 08, 2014 02:50AM |
Re: Printing Problems May 08, 2014 03:11AM |
Re: Printing Problems May 08, 2014 03:40AM |
robbycar
Nice work with the indicator! I was thinking one of the lever types as the springs seems lighter. I have quite a few of these that I use on my mill.
The alum x axis sounds good too.
Where can I get that?
Otherwise, I guess I can just make one.
Re: Printing Problems May 08, 2014 04:43AM |
Re: Printing Problems May 08, 2014 07:39AM |
OttoES
One more thing to check that got me: in some of the files the z axis is re-calibrated using the IR sensor which basically overrides your calibration ( it was the case in my g files that came with the printer) I had to manually remove the g code in the file before I got any thing working. (You can see it doing a re-calibration if it moves to all for cornets when you start a print)
One more tip not to do the IR calibration unless you are in a dark room with only LED light and standing on your left foot holding both thumps. To get going is is the easiest to just have a reasonable level bed and and do a simple G92 Z0 in the middle ( with which can can do small prints).
