My Printer is Printing now but i must be soon finished so can i speed up the Printer ???
Posted by Blitza
Hello all
I wanted to know if i can Speed up my Printer with some command under the Printing, since i Need to be done soon and the Normal Speed takes forever.
Hope someone give me an tip for it ^^
Greetings Mario
There are a couple of things you need to do to speed up the printer:
1. Put commands in config.g to increase the maximum allowed movement speeds, and possibly the accelerations too. I use this:
M201 X800 Y800 Z10 E350 ; set accelerations, increase E
M203 X12000 Y12000 Z180 E3000 ; increase max X, Y and extruder speeds
2. Change the slic3r parameters to use higher speeds. I have left the perimeter speed at 20mm/sec but increased solid infill to 40mm/sec, other infill to 60mm/sec, and travel to 200mm/sec.
Hi Dc
well i am under the Printing Process and wanted to Speed it up, is this even possible ?
It is possible do change the speed of the print, while it's actually printing, in the Marlin firmware (for older Arduino Mega-based boards) - [reprap.org]
However, it hasn't been implemented in the Duet firmware.
Ian
RepRapPro tech support
