forgot bed heating during printing May 14, 2014 07:21AM |
Re: forgot bed heating during printing May 14, 2014 09:25AM |
Re: forgot bed heating during printing May 15, 2014 09:33AM |
dc42
I'll try that print when I have time. How long do you expect it to take?
All hardware seams O.K.. By failing the print I can instantly press heat-buttun and the bed will warming up. (Yes, I use the standard ribbon cable.)Quote
dc42
It's possible that there is a bad connection somewhere and the 12V feed to the heated bed is dropping enough to affect the bed heating but not so much as to effect the stepper motors. I assume you are using the standard ribbon cable to feed the heated bed. Have you checked the 12V screw terminals on the Duet board and ATX board for tightness recently?
Thanks for this hint.Quote
dc42
You can connect for temperature inaccuracy using the M305 command.
Re: forgot bed heating during printing May 15, 2014 09:41AM |
Re: forgot bed heating during printing May 15, 2014 10:41AM |
Re: forgot bed heating during printing May 15, 2014 02:00PM |
Re: forgot bed heating during printing May 15, 2014 05:40PM |
Re: forgot bed heating during printing May 16, 2014 03:09AM |
dc42
Print completed.
What is it? Should I glue the pieces together and blow through it?
Re: forgot bed heating during printing May 16, 2014 03:11AM |
Re: forgot bed heating during printing May 16, 2014 05:19AM |
dc42
I tried that print yesterday. It got to a height of 16mm before the x-carriage slid off the linear bearing. I'll try it again today with a new x-carriage....
Re: forgot bed heating during printing May 16, 2014 08:43AM |
Re: forgot bed heating during printing May 16, 2014 10:15AM |
Re: forgot bed heating during printing May 16, 2014 11:42AM |
