9mm Bearing Sleeve
Posted by KimBrown
9mm Bearing Sleeve
May 14, 2014 08:39AM
Just released a 9mm Bearing sleeve so you can print them, remove the X-axis 9mm Bearing, Sleeve it, trim the sleeve, and fit it as the Y-axis idler.
The 10mm Bearing is then free to use on the X-axis......
Available Here..
