Bent y motor mount problem
Posted by Chaisaeng
May 15, 2014 04:15AM
Any one having this problem? I just reprint it an replace in my ormerod
but still thinking of reinforce it to mor rigid. The bent was due to heat generated from the motor over long period of continuous printing
The belt tension pull it so it will be seen prominently while it still installed in the printer.
Anyone having idea to reinforce it so it will stay square with few effort.
open | download - image.jpg (243.6 KB)
Re: Bent y motor mount problem
May 15, 2014 06:52AM
Chaisaeng
...The belt tension pull it so it will be seen prominently while it still installed in the printer.
thinking out loud here, the y-motor-bracket will alway give against the belt pull, no matter how solid the printed part is - better to use metal, we have the steel rods - design and print a support part for the two acrylic y-axis-end-plate (in the full length off) then use the 12mm y-rods against the belt pull - at the end point of the 12mm rods, make room for a nut and bolt to adjust against the ends of the steel rods (the steel rods are rough cut and of different size) - then we have something solid to hold rest the y-motor bracket against
Erik
May 15, 2014 06:57AM
If you stand the Ormerod feet on Paul's anti-vibration mounts or jack them up in some other way, then the y-motor will be higher off the ground. That would allow you to add a triangular fillet to the plastic part underneath the motor.
Edited 1 time(s). Last edit at 05/15/2014 07:24AM by dc42.
May 15, 2014 07:02AM
dc42
...That would allow you to add a triangular fillet to the plastic part underneath the motor.
..and make that in y-idler-end too
Erik
May 15, 2014 02:11PM
Thanks for all suggestion. .I think of something Erik do strengthen on both side of acrylic part
with square aluminum and maybe cutting another square aluminum for motor mount.
May 15, 2014 03:18PM
Chaisaeng
Another take could be to make a base plate of e.g. 4 mm aluminum - or maybe plywood would do if chosen a bit thicker - then mount this under the y-aluminum extrusion with 3mm T-nuts and screws, you would have to make a cut-out for the printed z-axis support part and ditto for the bed heater cable, the dimension could be something like 400x100mm, if you make it more than 100mm in the X direction you would also have to make out-cuts for the feet of the acrylic end parts to go through as they are a bit (4mm afair) under the level of the y-extrusion - or you could just chop 4mm of the acrylic parts (I did)
Then use this strong-against-belt-pull base plate to mount your supports for the acrylic end parts on - and another upside of a base plate would be the support of the heating bed cables
..and then put some handles on both side of the base plate for lifting the ormerod, better than carrying it in the z-axis
I may have to order a hardware kit and start all over again as there is so many different ways you can mod this thing :-)
Erik
May 16, 2014 08:19AM
Chaisaeng
..but you will IMHO be better off and your time better spend making angled aluminum supports for the acrylic parts bolted to the y-extrusion, then you will get horizontal strength against the pull of the y-belt and vertical strength to keep the bed stable - two for the price of one, what's not to like? :-)
Erik
May 16, 2014 08:21AM
Quite possibly the unmodified part printed in ABS instead of PLA would be sufficient. ABS won't get soft due to the motor getting hot, and I think it is also a stronger plastic.
Dave
(#106)
May 16, 2014 09:30AM
dmould
Dave
(#106)
ABS will be quite flexible so the belt tension may pull it making the thin motor mount arm bent.
It may not affect by heat generated by the motor but i think original design may need to modified to have it thicker or may be add some support underneath as DC42 suggest.
Edited 1 time(s). Last edit at 05/16/2014 09:31AM by Chaisaeng.
May 16, 2014 09:51AM
The back screw is what really holds the stepper in position, if you moved the motor out a bit there would be room for making the angle adjustable to compensate for the sag, not perfect I know..
Erik
