Nylon print May 19, 2014 04:49PM |
Re: Nylon print May 20, 2014 07:07AM |
Re: Nylon print May 20, 2014 07:28AM |
Re: Nylon print May 20, 2014 07:30AM |
Re: Nylon print May 20, 2014 07:45AM |
Re: Nylon print May 20, 2014 07:49AM |
droftarts
Have you got a link to the thread that talks about the herringbone extruder gears (and the Z gears)? I've added a link to the files on the Ormerod Improvements page, but it's good to link the discussion, too.
Ian
RepRapPro tech support
Re: Nylon print May 20, 2014 08:12AM |
Re: Nylon print May 20, 2014 11:09AM |
zombiepantslol
jstck: I know what you mean. The last material I used for printing was ABS, and I can see a few black bubbles in my printed parts. Probably some ABS was stuck inside the nozzle, but nothing I need to worry about I get the same effect you described when I switch from PLA to ABS, especially because it's quite difficult to remove the PLA completely from the nozzle. ABS is much easier to remove IMO (I usually do this at 160°C).
One thing that seems to be quite different from ABS and PLA is that Nylon appears to throw strings much more frequently, but I'm not using Taulman Nylon here. I hope I can get rid of them once my print has been finished. Also, I can hear my filament "cracking" when it melts - I'd blame humidity for that but I unpacked that spool just an hour ago. Everything is looking good at 5.5mm though.
