Double hobbed extruder May 28, 2014 02:52PM |
Re: Double hobbed extruder May 28, 2014 03:12PM |
Re: Double hobbed extruder May 28, 2014 03:33PM |
Re: Double hobbed extruder May 28, 2014 04:03PM |
Re: Double hobbed extruder May 29, 2014 04:02AM |
I will get this one a try it looks really good/JoarQuote
ormerod168
How about giving MasonStonehenge/VortyZA's Spring-loaded extruder a try?
RepRap Pro Ormerod Spring-loaded extruder
[www.thingiverse.com]
[attachment 33773 RepRapProOrmerodSpring-loadedextruder.JPG]
Erik
Re: Double hobbed extruder May 29, 2014 06:41AM |
Joar107
..I will get this one a try it looks really good/Joar
Re: Double hobbed extruder May 29, 2014 06:56AM |
Re: Double hobbed extruder May 29, 2014 07:38AM |
ormerod168
Good thinking, great design, thank you much to MasonStonehenge/VortyZA!
Erik
droftarts
I do like the look of the hinged extruder. The only problem I can see is that variable diameters of plastic cause different meshing of the gears. It would be better if just the idler was sprung, as in other extruder designs, though this means a general redesign and a more bulky extruder.
Joar - nice work on the double extruder, too! You can reduce a lot of the bulk of the filament input guide. As someone else suggested, you can run the ptfe further up the guide tube, and get rid of the thin walled part on the inside of the guide. It will be interesting to see how it performs.
Ian
RepRapPro tech support
Re: Double hobbed extruder May 29, 2014 07:48AM |
droftarts
...The only problem I can see is that variable diameters of plastic cause different meshing of the gears. It would be better if just the idler was sprung, as in other extruder designs...
Ian
Re: Double hobbed extruder May 29, 2014 09:58AM |
ormerod168
droftarts
Ian
..better yes agree, but do the math and you will see it is of no importance whatsoever
another thing I like about this design is that the force of the spring help keeping the bearings in place, one can keep a fairly loose fit and easily index the Hobbed insert to the filament, then mount the spring and it will wrap the printed part around the bearings
but no it ain't perfect, nothing is, always room for improvements, nudge, nudge, wink wink, say no more ;-)
Erik
Re: Double hobbed extruder May 29, 2014 10:42AM |
Re: Double hobbed extruder May 29, 2014 10:58AM |
VortyZA
...I like your change - so you have a problem with the tab falling out and the Bowden tube running away?
...I can make that change permanent if you'd like
Re: Double hobbed extruder May 29, 2014 10:59AM |
Re: Double hobbed extruder May 29, 2014 11:46AM |
ormerod168
You may not want to ad this, adding the flap makes it a tricky stand alone print as the heat will build up and destroy the flap if the nozzle is not diverted with other printing positions
Erik
Re: Double hobbed extruder May 31, 2014 04:54PM |
Re: Double hobbed extruder May 31, 2014 05:17PM |
VortyZA
I'll take a look when I get a chance. Wasn't there a nice clip replacement someone designed - hooks both in the hole and above?
