Double hobbed extruder
Posted by Joar107
May 28, 2014 02:52PM
i have problem that my filament get stripped a lot mostly because of fast printing, what do you guys think about a double hobbed extruder like this one [www.thingiverse.com] or this one [www.thingiverse.com]. And there is one called kraken that works with 2 nema 11.
I'm working now on a more ormerodish design but I would love to have some input.
/Joar
Re: Double hobbed extruder
May 28, 2014 03:12PM
I think it will solve one problem and create worse ones! My extruder motor usually stalls before the ABS filament is stripped, and I suspect that a stronger grip will not allow you to print significantly faster before you encounter the same issue. Then, if you were to stop that by increasing the power, I think that you would not get too far along that route before you start experiencing failures with the Bowden tube being pushed out at one end or the other (I have had that happen twice).
Dave
(#106)
May 28, 2014 03:33PM
How about giving MasonStonehenge/VortyZA's Spring-loaded extruder a try?
RepRap Pro Ormerod Spring-loaded extruder
Erik
May 28, 2014 04:03PM
I agree that i can get other problems but so far I havent had any big problems except for the first layer with power, here is some sketches
May 29, 2014 04:02AM
ormerod168
[attachment 33773 RepRapProOrmerodSpring-loadedextruder.JPG]
Erik
I will get this one a try it looks really good/Joar
May 29, 2014 06:41AM
Joar107
..I will get this one a try it looks really good/Joar
It's brilliant IMHO, adjustable spring pressure, same force of grip with variating filament diameter yet will not crush the filament as bearing will bottom out on the stepper, easy to service and clean, just swing open and look under the hood
..also make it easier to mount Matt's brilliant herring bone gears, always found it a bit hairy mounting those in one go:
Printed in ABS and sliced with Cura
M140 S110.000000
M109 T0 S240.000000
Layer height: 0.25 Walls: 1.5 Fill: 30
Notice that you will have to print those with support (if Cura, chose "everywhere")
Good thinking, great design, thank you much to MasonStonehenge/VortyZA!
Erik
May 29, 2014 06:56AM
I do like the look of the hinged extruder. The only problem I can see is that variable diameters of plastic cause different meshing of the gears. It would be better if just the idler was sprung, as in other extruder designs, though this means a general redesign and a more bulky extruder.
Joar - nice work on the double extruder, too! You can reduce a lot of the bulk of the filament input guide. As someone else suggested, you can run the ptfe further up the guide tube, and get rid of the thin walled part on the inside of the guide. It will be interesting to see how it performs.
Ian
RepRapPro tech support
May 29, 2014 07:38AM
ormerod168
Erik
It's a pleasure Erik - I like being able to give back to this community! I would be very pleased if you would post those pictures on thingiverse with an 'I made this' - they are great pictures!
droftarts
Ian
You're right Ian - there is a slightly different meshing of gears, but that's only with extreme cases of dodgy filament that it changes much during a print - the ratio of the gears remains the same.
I've done a couple of redesigns with a spring-loaded bearing being the only bit that moves, but each time I run into the size of the block becoming unwieldy.
Edited 1 time(s). Last edit at 05/29/2014 07:44AM by VortyZA.
May 29, 2014 07:48AM
droftarts
...The only problem I can see is that variable diameters of plastic cause different meshing of the gears. It would be better if just the idler was sprung, as in other extruder designs...
Ian
..better yes agree, but do the math and you will see it is of no importance whatsoever
another thing I like about this design is that the force of the spring help keeping the bearings in place, one can keep a fairly loose fit and easily index the Hobbed insert to the filament, then mount the spring and it will wrap the printed part around the bearings
but no it ain't perfect, nothing is, always room for improvements, nudge, nudge, wink wink, say no more ;-)
Erik
May 29, 2014 09:58AM
ormerod168
droftarts
Ian
Erik
I like your change - so you have a problem with the tab falling out and the Bowden tube running away? smiling smiley
I can make that change permanent if you'd like smiling smiley
May 29, 2014 10:42AM
VortyZA
..It's a pleasure Erik - I like being able to give back to this community! I would be very pleased if you would post those pictures on thingiverse with an 'I made this' - they are great pictures!...
Sure thing, will do!
Erik
May 29, 2014 10:58AM
VortyZA
...I like your change - so you have a problem with the tab falling out and the Bowden tube running away? smiling smiley
Yes a slight problem, left the printer alone a couple of hours and then....filament all over the place :-)
Not my change, cant model yet - the flap-under-the-gab is actually a part of Mr.Burns pfte-tube extruder mod that I have used up to now
[forums.reprap.org]
...I can make that change permanent if you'd like smiling smiley
You may not want to ad this, adding the flap makes it a tricky stand alone print as the heat will build up and destroy the flap if the nozzle is not diverted with other printing positions
BTW, did an upgrade from string to steel, so its no biggie :-)
Erik
May 29, 2014 10:59AM
bad quote day, sorry
Erik
Edited 2 time(s). Last edit at 05/29/2014 11:05AM by ormerod168.
May 29, 2014 11:46AM
ormerod168
Erik
Yes. I find any model that ends with just a small piece just at the top can suffer from this as the layers just take a couple of seconds and the layers don't get a chance to solidify.
I have a number of 'sacrificial' column stls of different heights and a couple of mm in size and I choose a higher one and put one or more of these into the slicer mix a distance away from the top part and this gives a bit of extra time for cooling.
I also added the tongue retaining flap to this excellent extruder design so I'd vote for that being a feature.
May 31, 2014 04:54PM
I'll take a look when I get a chance. Wasn't there a nice clip replacement someone designed - hooks both in the hole and above?
May 31, 2014 05:17PM
VortyZA
Correct, iamburnys Replacement Extruder Tube Clip:
"....not one of my best models as it is challenging to print being so small and does required support while printing the over hangs..."
Erik
