Re: New firmware 0.65e-dc42 and web interface 0.90 June 10, 2014 04:48PM |
Re: New firmware 0.65e-dc42 and web interface 0.90 June 10, 2014 05:00PM |
Re: New firmware 0.65e-dc42 and web interface 0.90 June 10, 2014 05:21PM |
Re: New firmware 0.65e-dc42 and web interface 0.90 June 10, 2014 05:25PM |
Re: New firmware 0.65e-dc42 and web interface 0.90 June 10, 2014 06:29PM |
Re: New firmware 0.65e-dc42 and web interface 0.90 June 30, 2014 09:10AM |
Re: New firmware 0.65e-dc42 and web interface 0.90 June 30, 2014 02:43PM |
Re: New firmware 0.65e-dc42 and web interface 0.90 June 30, 2014 04:27PM |
redblunt
first print over webterminal: print started imidiatly
without heating. the extruder cried.
Re: New firmware 0.65e-dc42 and web interface 0.90 June 30, 2014 04:33PM |
SlinBin
Running: Duet Firmware: 0.65j-dc42 with reprap.htm: 0.95
I can not control the extruder temp in the web interface, and neither can the Slic3r g-files (Bed control is ok)
Re: New firmware 0.65e-dc42 and web interface 0.90 July 01, 2014 08:54AM |
dc42
It very much sounds like a T0 vs. T1 or G10 P1 vs. G10 P0 issue. Please go to the Settings page in the web interface and confirm that it says you really are running 0.65j-dc42 and web interface 0.95.
Any slic3r gcode files that you previously generated will need to be modified, to change T0 to T1 and to put this command before the G109 command that slic3r generates to set the extruder temperature. See the first post in this thread about changing the slic3r start gcode.
Re: New firmware 0.65e-dc42 and web interface 0.90 July 01, 2014 09:15AM |
Re: New firmware 0.65e-dc42 and web interface 0.90 July 01, 2014 09:21AM |
Re: New firmware 0.65e-dc42 and web interface 0.90 July 02, 2014 09:33AM |
dc42
1. Can you confirm that in the Settings page, both reprap.htm and reprap.js are showing as version 0.95? Also that you copied all the web files over to the SD card into the appropriate directories, including the new bootstrap-slider js and css files?
2. If you do control-shift-J to get the Javascript console in Chrome, does it show any errors?
3. Does the extruder heat up if you send T1 and then e.g. M104 S100 using the Send Gcode box in the web interface?
4. When the extruder won't heat up, does it show a reasonable temperature e.g. close to room temperature?
5. Regarding not being able to control the hot end after the print finishes, that could be partly due to your end gcode in your slic3r files - what end gcode do you have?
Re: New firmware 0.65e-dc42 and web interface 0.90 July 02, 2014 12:51PM |
Re: New firmware 0.65e-dc42 and web interface 0.90 July 03, 2014 08:01AM |
Re: New firmware 0.65e-dc42 and web interface 0.90 July 03, 2014 08:21AM |
SlinBin
REQUEST !
Can anybody guide me as how to tell the Duet to turn on the heater by direct control over USB via Arduino software (without using any onboard software/firmware) ?
I would love to make this test to rule out problems with the board/wiring
Re: New firmware 0.65e-dc42 and web interface 0.90 July 03, 2014 08:38AM |
Re: New firmware 0.65e-dc42 and web interface 0.90 July 03, 2014 11:53AM |
Re: New firmware 0.65e-dc42 and web interface 0.90 July 03, 2014 12:06PM |
SlinBin
But related to bad plugs on the pins connecting my hotend wires on the duet board (very suprising considering that there are to for + and 2 for -, so both of one kind must have been pluged in but unconnected).
Thank you for looking into my problem
Sorry if I created confusion in the thread and especially if I did about DC42finebrilliant work.
I am happy printing with 0.65j-dc42 and 0.95 (
