X and Y calibration issue
Posted by Squags
June 05, 2014 07:56AM
Hi all,
I've just put together my 2nd Ormerod, which seems to have come with its own problem:
The X and Y calibrations aren't right, meaning circles don't come out right - see picture...
Any ideas what I can adjust to try and sort this problem?
Cheers,
Squags
open | download - Picture3.png (384 KB)
Re: X and Y calibration issue
June 05, 2014 01:21PM
One hole looks round, could it be a belt slipping or motor losing steps???
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
June 05, 2014 01:50PM
The only things I can think of that would cause the X and Y axes to move by different amounts are:
1. X or Y belt too loose, or Y belt slipping.
2. Stepper motor missing steps, due to the belt or other part of the assembly being too tight, or insufficient stepper motor current.
3. Firmware bug (but I presume you are using the same firmware as many other users).
4. M92 command in config.g (or gcode file) that sets different numbers of steps/mm for the X and Y axes.
5. Different numbers of teeth on the X and Y stepper pulleys.
6. Different model X and Y stepper motors, with different numbers of degrees rotation per step.
Like Davek, I suspect (1).
EDIT: I just thought of:
7. Print shrinking by different amounts along X and Y axes when it cools. But I can't think what would cause that.
Edited 1 time(s). Last edit at 06/05/2014 01:52PM by dc42.
