Z Probe wiring
Posted by imekon
Z Probe wiring
June 07, 2014 04:14AM
I've just finished putting together my Ormerod kit and I'm finding issues with the Z probe. The connector on the loom has lugs on it that foul the plastic. It seems to work itself loose as the head moves around.
The symptoms are that X axis home sometimes fails. Home all axis command G28 buries the head in the bed. Yet if I try Z Home, it stops exactly where it should, where I set it.
G31 is reading values and I'm seeing results consistent with the instructions, but the way the connector moves makes me think that needs sorting out.
Re: Z Probe wiring
June 07, 2014 04:19AM
I had the same problem. The connector would not seat properly.
To fix it, I loosened the probe board, then firmly seated the connector, then refastened the board screws.
Should fix the issue.
Rob.
Re: Z Probe wiring
June 07, 2014 04:38AM
Yeah, I tried that but the lugs prevent the board from lying flat against the plastic. I'm wondering if I should slice off the lugs?
Re: Z Probe wiring
June 07, 2014 04:40AM
I was always having issues with my probe connector so I soldered the wires directly to the pins and covered them in heatshrink.
Regards,
Les
Pointy's Things
Pointy's Blog
Re: Z Probe wiring
June 07, 2014 04:55AM
Soldering it might be my best solution.
Re: Z Probe wiring
June 07, 2014 05:21AM
Or use one of my hot end boards instead, which uses locking connectors smiling smiley
Re: Z Probe wiring
June 07, 2014 03:43PM
I unplugged the sensor, snipped off the lugs that got in the way, reseated the probe. I plugged back in, cable tied the cable so it won't tilt as the head moves. X Home and Z Home work fine now.
Yet the command G28 still buries the head in the bed - this is in the test files; if I home X, Y and Z manually, fine. Yet, G28 zeroes Z to somewhere different (X is not 55). Am I missing something?
Re: Z Probe wiring
June 07, 2014 04:45PM
The coordinates at which z homing is done are defined in files homez.g and homeall.g in the sys directory of the SD card. If G28 Z0 works but just G28 does not, then the coordinates in homeall.g are wrong. You need to set the coordinates to be over the white tape in the corner of the bed. I suggest you use the same coordinate as your first bed compensation coordinate.
Re: Z Probe wiring
June 07, 2014 05:07PM
Thanks, that makes sense. I'll check when I get back.
Re: Z Probe wiring
June 08, 2014 01:37AM
Fit a switch.....
It ALWAYS works......
Re: Z Probe wiring
June 11, 2014 06:09PM
So I updated my homeall.g file and...
The cube is hollow, the snowman I aborted.
Edited 1 time(s). Last edit at 06/11/2014 06:10PM by imekon.
open | download - first prints.jpg (134.1 KB)
Re: Z Probe wiring
June 11, 2014 06:33PM
It looks to me like your hollow cube print started OK but then went blobby, and the snowman went blobby sooner. Here are some things to check:
1. Are you using a recent firmware version, either RepRapPro 0.65e firmware or my own 0.65f-dc42 firmware? Send command M115 to find out.
2. What temperature does the snowman file use for the hot end? The temperatures set in the SD card files shipped with early Ormerods set the temperatures too high. I suggest no more than 195C for the first layer and no more than 190C for subsequent layers. Blobby prints are often an indication of too high a temperature.
3. Does the filament move smoothly through the extruder during printing?
4. The filament needs to be protected from high levels of humidity, otherwise it absorbs moisture, which reduces print quality.
Re: Z Probe wiring
June 11, 2014 09:32PM
I'm using latest firmware.
If I extrude 100mm it judders a little. While printing it was smooth.
I raised the z axis by 1mm and tried again, it went better. It looks as though the head is touching the plastic as it starts but gets better and more stable higher up.
Re: Z Probe wiring
June 12, 2014 04:39PM
MUCH better results once I set the bed levelling compensation. Now I get a 20x20x20mm cube.
hot smiley
Re: Z Probe wiring
June 12, 2014 04:55PM
imekon
hot smiley
A couple of tips for using the bed compensation:
1. Bright sunlight or incandescent light will affect the reading of the sensor. So shield the Ormerod from these types of light when doing z-homing or bed compensation. Fluorescent and incandescent light is OK.
2. You will have chosen the bed compensation coordinates to be near the middle of the white targets at the corners of the bed. However, the coordinates used for z-homing may not be in the middle of a white target, leading to unreliable homing. So edit the homex.g files and homeall.g files in the sys directory of the SD card, changing the XY coordinates in the line G1 X55 Y0 to whatever coordinates you used for your first bed compensation point.
