Data of fan? June 08, 2014 10:15AM |
Re: Data of fan? June 08, 2014 12:04PM |
Re: Data of fan? June 08, 2014 12:18PM |
Re: Data of fan? June 08, 2014 12:33PM |
Re: Data of fan? June 08, 2014 12:43PM |
Re: Data of fan? June 08, 2014 02:46PM |
Re: Data of fan? June 08, 2014 02:48PM |
Treito
Okay thanks, but the technical data I woud need is not there listed, only guesses (CFM). But it is a little bit poor that the bearing is damaged only after three days of using and only one successfull .
Re: Data of fan? June 08, 2014 03:22PM |
Re: Data of fan? June 08, 2014 06:21PM |
dc42
The problem with using a quieter fan is that it will probably be less effective at cooling; but perhaps effective enough. Alternatively, you can install one of my hot end boards that replaces the z-probe, adds lighting, and only turns the fan on when the hot end is above 40C. Then the fan is only on during printing and cooldown, not when the printer is idle.
Re: Data of fan? June 09, 2014 07:43AM |
Re: Data of fan? June 09, 2014 07:52AM |
Re: Data of fan? June 09, 2014 09:56AM |
Treito
The new y-idler-ends should be on the way. Also the z-upper mount, but this did fit. I had some very little problems with the support, because you cannot order here directly at RS.
BTT. There is something wrong with the bearing definitely. When I start the ormerod the fan makes really loud noises and does not run at full speed. My guess is that the fan wheel can move a little bit and the impreller (if this is called so) contacs the case or something else. I have often seen problems like this, but not that fast. I found one fan with more power and less noise - theoretically. Datasheet of fan
I am not familar with this kind of connection. Is it possible to remove the pins of the old fan without a special tool? Otherwise I would connect it directly to the duet board.
Re: Data of fan? June 10, 2014 03:43AM |
dmould
and there have so far been no cooling-related issues after printing about 8Kg of ABS to date.
Does your Ormerod never sleep?|
Re: Data of fan? June 10, 2014 07:34AM |
Pointy
dmould
Les
