Can this bottom curve be improved?
June 09, 2014 11:38AM
This has always happened and I have put up with it. The top of the curve prints OK but the bottom just doesn't follow the design correctly
As you can see the bottom curve is almost straight, it should mirror the top curve.
I have played around with cooling, hot-end and bed temperatures, slic3r settings and nothing seems to work.
I am starting to think that maybe this is a problem with slic3r and not an ormerod problem at all.
Any advice and help will be much appreciated.
Paul
appjaws - Core XYUV Duet Ethernet Duex5
firmware 3.1.1 Web Interface 3.1.1
Ormerod 1-converted to laser engraver, Duet wifi
OpenSCAD version 2020.07
slic3r-1.3.0, Simplify3D 4.1.2, Cura-4.4.1
Re: Can this bottom curve be improved?
June 09, 2014 02:12PM
Are you printing with support? And what temperatures do you extrude at?
June 09, 2014 03:43PM
No support, it is such a small item. Would support work on a 5 mm curve?
I have the extrude temperature set at 194 after the fist layer. I also have secondary cooling fans.
I have never used support, it just didn't occur to me that that could help, perhaps I'll try it in the morning.
June 09, 2014 04:55PM
If I'm designing things that I want to print without the use of supporting material, then I'll make sure that overhangs don't exceed 45 degrees from vertical. Much more than that and the material will either droop or be dragged around by the head a little! smiling smiley
So a curve like the one you show there would start with a 45 degree, then curve nicely towards the top.
Occasionally I'll have to use support mainly because I can't think of any way of sticking to the 45 degree rule, but I prefer not using it as it requires removal which can be difficult and leave traces.
I'm also intrigued by the near bottom right hand side of the model you're printing - what is happening there?
June 09, 2014 05:04PM
VortyZA , Thank you for your comments
I'm not sure what you mean, the bottom right is just a straight 90 degree angle, the two uprights are finished off with a nice curve above the screw holes.
June 10, 2014 03:11AM
Hi Paul,
For what it's worth I have always struggled printing upwards slopes or curves. The original Z Nut Trap piece is a good example of this and I had to print it several times to get a good one. I think it's a cooling issue as I seemed to get better results when the slope is facing the fan duct. I noticed that the upward slope would always curl upwards which meant it went lumpy and would make the nozzle jump.
Try rotating your piece 90 degrees so that the curves face the fan duct and also lower your hotend temps, your print looks stringy which is a sign of too much heat. I use 190 for first layer and the 185 for the rest.
The other interesting thing is that we both use a very similar fan duct...
Maybe we can make a test piece that others can print to verify the problem. Whatis the dimensions of the piece with the curve?
Regards,
Les
Pointy's Things
Pointy's Blog
June 10, 2014 04:50AM
Pointy
Les
Les,
I will try turning the item through 90 degrees and see if that helps..
My fan duct has 3 outputs, centre directed at the nozzle and the 2 outside directed forward and downwards. I'm going to try the original fan again because I think I need more airflow.
The end of the item is a U shape 10mm tall, 23x21mm with 4mm thick walls and a radius of 5mm on the ends
We should do some tests.
I'll try later but I only have today to work on this.
Thank you for your interest
Paul
June 10, 2014 06:09AM
Part of the item for testing.
open | download - curve-test-stl.zip (142.6 KB)
June 10, 2014 07:07AM
I just printed that piece with my default settings...
Sorry, it's not the best picture, but it didn't come out too bad. It's definitely not as round on the bottom, but it's not as bad as yours. I also didn't rotate it, so it was printed the same direction as in your photo.
Regards,
Les
Pointy's Things
Pointy's Blog
June 10, 2014 07:31AM
I think printing a piece like that with a large radius curve on the bottom is asking for trouble. Can you not add a small fillet to partly fill in the gap at the bottom, so that you have a 45 degree overhang instead of an overhang that starts at (in the limit of zero extrusion width) 90 degrees?
Edited 1 time(s). Last edit at 06/10/2014 07:32AM by dc42.
June 10, 2014 07:38AM
Les,
Can I have a copy of your settings to try please.
Looking at your picture, he ones I have printed today are as good, but it would be interesting to compare settings
I have dropped the temperature by 2 degrees and I think that has made the difference, an improvement over yesterdays.
I have printed 1 rotated 90 degrees - an improvement but still a straight line.
Also printed with support selected in slic3r but I can not see any support on the print, again a straight line.
Not ever having used support what should the settings be?
Paul
June 10, 2014 07:50AM
One other thing to try is to reduce the layer height. That will result in less overhang distance per layer. Also make sure you uncheck the Slic3r option "Print external perimeters first" (Last option in "Print Settings/Layers and perimeters"). If the inner perimeter is printed first, it provides some sort of side support for the outer perimeter even if the outer perimeter is unsupported underneath.
Dave
(#106)
June 10, 2014 08:16AM
appjaws1
Les,
Paul
I have attached my Slic3r settings. I have never used support either so can't help with that.
Regards,
Les
Pointy's Things
Pointy's Blog
open | download - Ormerod-0.5-pointy.zip (1.9 KB)
JMC
June 10, 2014 08:21AM
I have been trying to print your test piece but every time i try to save the Gcode with slic3r it crashes. This is the only file i have had that happen ? did you all use slic3r for the above print.
June 10, 2014 09:46AM
Hmmmm it's interesting hearing about this.
Reducing the layer thickness would help.
When I print stuff like that I put in my own snapable supports. The Big Blue has allot of thin support walls under it to hold it up while printing, that are thin enough to snap out with your fingers afterwards.
I wouldn't use Slic3rs support structures on anything, as I find they are terrible.
To support those downward curves I would place a very thin wall at each edge, so the print head could Bridge between them as the curve builds up.
Add them to your design, then you know where the supports are, and that they won't interfere with your design, and you can make them easy to remove. If Slic3r does it, then it'll be a mess...
I wouldn't use external fans either, as your picture shows signs of Warping, and they will just make it worse.
With the Big Blue, the second fan on my duct is under Slic3r control, and it does a pretty good job at warm areas with a Bulk of plastic, by blowing extra air through the ducts.
The temps I run with are 195' and 57'
It would be interesting to see your machine run the Bridging test... With and without the external fans.
Edited 1 time(s). Last edit at 06/10/2014 09:54AM by KimBrown.
June 10, 2014 09:54AM
dmould
Dave
(#106)
Dave,
I completed a print with layer height of .1 and the problem is exactly the same, see photo. I also have the settings that you suggest.
Pointy - Thank you for your settings, they are very close to mine, the only difference is the speed of some items.
JMC - I think we have all used slic3r to slice the test stl.. What version are you using?
I have reverted to using 1.1.3, as 1.1.4 had problems. Does the part show in slic3r's viewer?
Paul
JMC
June 10, 2014 12:38PM
appjaws1
dmould
Dave
(#106)
Dave,
[attachment 34638 point-one-layer-height-test.jpg]
Paul
Havent updated in a while so am using an older version. Is a bit academic at the moment sins i have busted somthing so can not print now any way. But from your pictur it looks like a problem i had when i was using a large external fan for print cooling and was only colling from one direction. if i watched closely while printing i could see the very edge warping a little whitch tended to make the underside of curves more of a diagonal. To fix this i got a very powerful little blower fan and ducted the air so the print was cooled from 4 sides in a kind of spiral fashion. Another mod that seemes to help stop edges curling is to use warme air to cool the print this way you can blow more air across the print without cooling doun the hot bed. My previos rig had the air blowing on to the print at about 45C. will print your test shape as soon as i find out what is shorting out my power supply confused smiley
JMC
June 10, 2014 02:25PM
Its a bit hard to take a good pictur
The upper and lower sides of the curve are not completly symmetrical but there close. Have printed several tests with diffrent amounts cooling but its 2 am and i have to work in the morning so will post them tomorro.
June 10, 2014 02:40PM
JMC
[attachment 34675 WP_000483.jpg]
From what I can see the result looks good, better than mine.
Unfortunately I'm not around for the next few weeks but will be very interested in anything you come up with to improve the curves.
Paul
June 10, 2014 03:55PM
Reverted to the original ormerod fan which produces a much better air flow compared to the quiet fan I was using.
The result is a great improvement on the lower curves, still not correct but much better.
JMC
June 11, 2014 03:55AM
Here are 4 tests i printed with diffrent cooling. all are at a layer hight of .24 a bed heat of 60C and a hot end temp of 180C (first layer 70C and 200C)
I cut the ends off to get better pictures (the center holes are all round tho they dont look it in the pic).
This is the cooling rig i used that blows air on to all sides of the print.
I have modifide it since this to create more of a whirlwind affect and to allow for hot air to be used.
June 11, 2014 05:48AM
how warm is "warm air" approximately?
JMC
June 11, 2014 11:23PM
auser
About 40 to 45C
June 12, 2014 11:16AM
thanks a lot
June 12, 2014 03:10PM
appjaws1
[attachment 34692 test-original-fan.jpg]
Mine happened to be exactly the same result as yours. Looking fir solution for this for a while yet stil
not found any setting that can get it better. Hope there is an answer to this issue soon.
June 12, 2014 05:33PM
Have you properly leveled your bed? It almost looks like your bed is too low, but I haven't really looked at other parts of the print.
Edit: Looked, you've got some bad z-banding. What screw, if any, are you using for Z axis? Steps per mm you have set?
Edited 1 time(s). Last edit at 06/12/2014 05:34PM by MrDoctorDIV.
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
July 15, 2014 10:01AM
As the radius gets larger for bigger parts, this issues is just going to have a larger effect. The larger the radius, the more layer are below 45 deg. Do you think there is a good solution for printing these curved parts without support for all situations? Imagine printing a sphere for example.
I'm interested in printing tubular structures that would have portions forced to be printed horizontally.
Edited 1 time(s). Last edit at 07/15/2014 10:06AM by paradiddle65.
July 15, 2014 11:45AM
No, larger curves (and horizontal holes) need to be printed with support. Cura does a better job of generating support that snaps off easily than Slic3r. With holes, you need to select "print support everywhere" in Cura otherwise holes wont get any support.
The support often makes the print appear to be a complete mess, but it's surprising how easily it can be removed to reveal a good print underneath.
Dave
(#106)
