New firmware 065g-dc42 and web interface 0.91 June 14, 2014 07:46PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 14, 2014 10:07PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 15, 2014 04:15AM |
Re: New firmware 065g-dc42 and web interface 0.91 June 16, 2014 05:14PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 17, 2014 12:25AM |
Re: New firmware 065g-dc42 and web interface 0.91 June 17, 2014 12:52AM |
Re: New firmware 065g-dc42 and web interface 0.91 June 17, 2014 03:31AM |
paflviet
Ok, it looks strange to have M104 followed by M109, but that's what Slic3r generated, but that's not an issue. Executing these lines manually one after another (that's why I'd appreciate the command echo !), it appears that M109 reboots the Duet.
The same test performed with Pronterface ends the same, I even simplified the test by sending a single M109 command : power on the printer, connect either with a browser or Pronterface, send M109 and you're done :-(
paflviet
I've a question for you, for my curiosity : why are you developing your own firmware and web console versions rather than working on the main stream ?
Re: New firmware 065g-dc42 and web interface 0.91 June 17, 2014 04:03AM |
Re: New firmware 065g-dc42 and web interface 0.91 June 18, 2014 04:05AM |
Re: New firmware 065g-dc42 and web interface 0.91 June 18, 2014 04:59AM |
Re: New firmware 065g-dc42 and web interface 0.91 June 18, 2014 01:36PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 18, 2014 01:45PM |
paflviet
Hi dc42,
I'm trying your 65g-dc42 firmware and have some comments to do about it :
- reloading the HTTP page seems to reboot the Duet. The procedure to test is easy : access your printer IP with a browser, connect, reload the page, re-connect and check the message log. If you have a Pronterface running at the same time, you can see the firmware version being displayed in its console.
paflviet
- I tried to upload a Gcode file generated with Slic3r, and it seemed to crash or stuck my printer every time. The beginning of this file is :
...The same test performed with Pronterface ends the same, I even simplified the test by sending a single M109 command : power on the printer, connect either with a browser or Pronterface, send M109 and you're done :e
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 03:23PM |
Ok, understood.Quote
dc42
No, it doesn't reboot the Duet. However, whenever the browser connects, it sends the M115 command so that it can display the firmware version. That is why you can see the firmware version being displayed in the Pronterface console. If it really did reboot the Duet, and you are running Pronterface under Windows, then you would lose the connection with Pronterface. if Pronterface didn't disconnect on a reboot, then you would see the "Network up, IP=..." message.
I'm now running your 65h firmware which seems to handle well the M109 bug.Quote
dc42
I'm fairly sure this was caused by the M109 bug that I have already mentioned in earlier posts, and which is fixed in version 0.65h. I think that somehow you must have ended up with an invalid tool selected when the M109 command was executed. Although you posted your config.g.file, you didn't post the gcode file you were running, so perhaps there was something in the gcode causing an invalid tool selection, or in setbed.g or something else you run before you try to print..
, I tried to send a second print to benefit of the Z compensation which is supposed to be ok. The G-code file of this second printing is executed as expected, but the head doesn't heat. I suppose it's related to some Tx command, certainly a bad tool is selected :|
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 04:26PM |
paflviet
I've another issue but still don't know if it's related to Slic3r or the firmware, I hadn't enough time to run more tests. When a print is finished, as I'm a lazy boy and like to avoid efforts as much as possible, I tried to send a second print to benefit of the Z compensation which is supposed to be ok. The G-code file of this second printing is executed as expected, but the head doesn't heat. I suppose it's related to some Tx command, certainly a bad tool is selected :
- if Slic3r is involved, a Tx (T1 I guess) has to be added as a prefix of the printing. Easy to do.
- if the firmware is involved, I suppose some Tx order has been executed, T1 I guess, _before_ executing any G-code file in order to reset the printer in an initial well-known state.
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 05:32PM |
That was it, I added T1 in the Slic3r / Printer settings / Custom G-code / Start G-code and it's fine.Quote
dc42
I've just checked, and the firmware sets the current tool to -1 when M0 or M1 is executed. So you need to execute T1 before printing again, either by having slic3r do this in the start gcode, or manually.
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 05:36PM |
uet DATE:2014-06-18"|
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 06:13PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 06:17PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 06:26PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 06:50PM |
M550 PDave's Ormerod; Set the machine's name
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 06:57PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 07:02PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 20, 2014 07:05PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 21, 2014 03:58AM |
var resp = $.askElle("name");
if (resp.hasOwnProperty('myName') && resp.myName.length != 0) {
$('span#machineName').text(resp.myName);
Re: New firmware 065g-dc42 and web interface 0.91 June 21, 2014 04:37AM |
Re: New firmware 065g-dc42 and web interface 0.91 June 21, 2014 09:58AM |
dmould
On the other hand the "disconnected" error messages occur only when I disconnect/reconnect by hand so are not significant ...
Also just tried I.E. and Firefox - both connect but with the same problem.
{edit} in case it's of help. attached is my SD image (all except "gcodes" folder)
Re: New firmware 065g-dc42 and web interface 0.91 June 21, 2014 01:11PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 26, 2014 04:19PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 26, 2014 04:55PM |
Re: New firmware 065g-dc42 and web interface 0.91 June 26, 2014 05:00PM |
