Cura/Slic3r/G-code issues June 25, 2014 05:34AM |
Re: Cura/Slic3r/G-code issues June 25, 2014 07:51AM |
Re: Cura/Slic3r/G-code issues June 25, 2014 08:56AM |
Re: Cura/Slic3r/G-code issues June 25, 2014 11:20AM |
droftarts
Try opening the file in Netfabb Basic (free) and check if there are any problems with it, ie not 'watertight', as it may have holes in the model mesh. Often it's that there are 'intersecting faces', ie triangles that go through each other. I've had problems with Blender models before. Different slicers have different strategies for coping with holes, so you'll get different results.
Ian
RepRapPro tech support
dc42
How thick are the walls in that part? Slic3r often has problems generating correct gcode if the walls are thinner than 2 extrusion widths.
Re: Cura/Slic3r/G-code issues June 25, 2014 11:54AM |
Re: Cura/Slic3r/G-code issues June 25, 2014 12:19PM |
dc42
I don't understand, if the walls are 0.48mm thick and you are using the standard 0.5mm nozzle then the walls are only 1 extrusion width thick - which slic3r will have a problem with.
Sardi
The walls are 2 widths by 0.24mm thick, so 0.48mm. So that gives the answer about Slic3rs problems.
Re: Cura/Slic3r/G-code issues June 25, 2014 01:36PM |
Re: Cura/Slic3r/G-code issues June 25, 2014 02:04PM |
dc42
How are you getting 0.24mm extrusion width? Do you have a 0.3mm nozzle?
Re: Cura/Slic3r/G-code issues June 25, 2014 03:00PM |
Re: Cura/Slic3r/G-code issues June 25, 2014 03:28PM |
Re: Cura/Slic3r/G-code issues June 25, 2014 03:32PM |
Re: Cura/Slic3r/G-code issues June 25, 2014 06:21PM |
Re: Cura/Slic3r/G-code issues June 26, 2014 01:28PM |
Re: Cura/Slic3r/G-code issues June 26, 2014 05:13PM |
Re: Cura/Slic3r/G-code issues June 26, 2014 05:51PM |
Re: Cura/Slic3r/G-code issues June 26, 2014 06:23PM |
