Re: Bed leveling issue - how is this even possible? June 15, 2015 03:39AM |
Dark Alchemist
Same here and I have tried everything but after 1.5 years and thousands of hours to get this thing to work I give it up today. Just too many issues to have fun with it imo and I don't care if it is PEBKAC or there really are issues in the printer I haven't printed enough to actually have fun. All aluminum I3 Rework with mods galore and nothing fixed the 4 corner ball buster so it isn't just the Ormerod that has these issues.Quote
Sardi
It seems to me that this printer is a lot of work. Ive bought it for home fun, but must admit Ive spent more time tuning it then printing. I already have DC42s sensor, modified heat sinks, Z rod gears, extruder gears.. and now I need an aluminium bed plane and maybe aluminium X rib... Does this ever end?
I know this is a kit, but when you need to purchase and print a bunch of additional parts for it to work properly, than it just isnt worth the money or the time. Will think about daveks aluminium plate, but then I can just hope that this is the last update Ill need.
Ive literllay spent more time fixing this machine than enjoying the prints.
OT:
I have zeroed the Z in the middle (x100 y100) and it seems to do just fine. For now at least.
Re: Bed leveling issue - how is this even possible? June 15, 2015 09:44AM |
Dark Alchemist
Sardi
OT:
Re: Bed leveling issue - how is this even possible? June 15, 2015 09:54AM |
Re: Bed leveling issue - how is this even possible? June 15, 2015 11:09AM |
I had used ABL for a long while and it sucks for a cartesian printer. Wear, tear, and slow as hell. The fact is on my i3 rework it cannot be leveled and I have spent 1.5 years trying to get it to print reliably. Now it doesn't print at all but, I guess, if I went to a 1mm nozzle and print with 0.8mm layer height for the first layer maybe, just maybe, it would work. No one has been able to figure out where the issue is but the issue is in the printer itself as there is a bulge in the middle of the printbed no matter what you put on it. MK2B, bulge. MK2B+Aluminum Heat Spreader, bulge. MK2B+Boro glass, bulge. MK2B+Aluminum Heat Spreader+Boro Glass, bulge. Get all 4 corners to be the same distance from the nozzle and the center is bulged. Release all of the nuts (letting it free float) and I can getthe same reading front to back so it is not X bar sag in the middle.Quote
dmould
As an aside, I don't like using bed compensation because of the wear on the Z nut and gears. A while back I suggested that the bed compensation could be applied to the first layer as at present but then progressively reduced over the following 3 or 4 layers so that the bulk of the print was achieved with no Z screw grinding. At the time the feeling was that it was be a reasonable idea, but there were bigger fish to fry wrt firmware changes at the time. I'm wondering whether it is still considered a good idea, and if so whether DC42 or Zombie might be interested in trying an implementation.
Dave
Re: Bed leveling issue - how is this even possible? June 15, 2015 11:34AM |
Re: Bed leveling issue - how is this even possible? June 15, 2015 11:41AM |
Who in the hell is comparing one printer on another? I am not I was agreeing with his sentiment which I have. His may be on another printert than mine but the sentiment was exactly the same. A freaking nightmare of hell trying to get a pea, or an apple, or a watermelon to print on a consistant basis.Quote
Treito
You cannot compare a Prusa with an Ormerod. ABL worked perfectly for me even with the original sensor from the MK1. It was far better then leveling by hand. It is not fair to compare two totally different printers with a completely other structure, controller and behavior. You compare apples with peas. The Ormerod is a totally enhancement to the Prusa.
Re: Bed leveling issue - how is this even possible? June 03, 2018 09:56PM |
Re: Bed leveling issue - how is this even possible? November 15, 2018 06:04PM |
