Experimental firmware 0.78a-dc42 July 06, 2014 06:22PM |
pin 2 > ......................... < pin 50 pin 1 > ...................ST.... < pin 49
Re: Experimental firmware 0.78a-dc42 July 07, 2014 05:44AM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 07:24AM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 07:28AM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 09:43AM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 01:01PM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 02:08PM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 03:58PM |
dc42
* The Z probe blue wire (and the white wire, if you are using one of my hot end boards) connect to different pins, like this:
S is the ZProbe signal output (blue wire, 6th pin from right, bottom row). T is the trigger/modulator input (white wire if you are using one of my hot end boards, 5th pin from right, bottom row).
Re: Experimental firmware 0.78a-dc42 July 07, 2014 04:27PM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 04:38PM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 05:11PM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 06:35PM |
Re: Experimental firmware 0.78a-dc42 July 07, 2014 06:42PM |
muggi
But the webinterfaces crashes if i want to home my x,y,z axis.
The log shows the message : The webserver pobably broken.....
Re: Experimental firmware 0.78a-dc42 July 07, 2014 10:56PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 04:13AM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 10:36AM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 11:15AM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 11:53AM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 12:34PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 01:10PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 01:21PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 02:34PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 03:24PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 03:31PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 04:04PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 04:08PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 04:15PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 04:19PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 04:30PM |
Re: Experimental firmware 0.78a-dc42 July 08, 2014 04:47PM |
