Hot End Not Turning On July 14, 2014 09:38PM |
Re: Hot End Not Turning On July 15, 2014 02:15AM |
Re: Hot End Not Turning On July 15, 2014 04:35AM |
Re: Hot End Not Turning On July 15, 2014 12:21PM |
ezwul
I think you have not defined a tool, there are none defined by default and your old config.g will not have the new G-Codes, so you need to add the following in your config.g
M563 P1 D0 H1 ; Define tool 1 to use extruder drive 0 and heater 1 (heater 0 is the hot bed)
G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
I was not getting temp readings until I did this.
You should probably check all your homeing files as well to make sure they are still compatible.
