Re: Laser cut Aluminium X-Arm & Rib kits.... November 27, 2014 04:40AM |
Motoray
Hi Crouchy,
I would be interested in an Ormerod 1 arm & rib at AU$40 + post, let me know how to proceed. My rib is broken and I made an Aluminium angle to support the arm which helped, but it still wobbles a bit when printing, so not good!
I am in Mudgee NSW (2850) Australia
Ray
Re: Laser cut Aluminium X-Arm & Rib kits.... November 27, 2014 06:30AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 27, 2014 12:57PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 27, 2014 01:27PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 27, 2014 02:30PM |
Mick747
Ah ok my bad then so would just need X axis parts. There is an mdf bed that everything sits on and thought that was the item being replaced.
Re: Laser cut Aluminium X-Arm & Rib kits.... November 27, 2014 04:55PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 28, 2014 07:04AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 28, 2014 07:25AM |
Davek0974
On the Mk2 there are three locating lugs on the rib and mating holes on the arm, if we are using screws, these would seem to be not really needed as the screws will both locate and fix the two parts.
Could someone back me up on this?
Re: Laser cut Aluminium X-Arm & Rib kits.... November 28, 2014 08:30AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 28, 2014 08:58AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 28, 2014 09:38AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 28, 2014 10:14AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 28, 2014 11:29AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 28, 2014 11:39AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 10:46AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 11:07AM |
pandionx
Dave, given that you're not going to cut more of the X-Arms for the model 1, would you mind posting the DXF's for them please?
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 11:15AM |
Davek0974
pandionx
Hi
I am on the verge of getting a batch of 5 made as others are wanting them too, please wait a little longer.
I'm about 99.9% done in getting the Ormerod Mk2 Aluminium X arms and ribs ready to cut, can I get a scale of the demand for these please, just a quick yes please will do at this point.
Many thanks
Dave
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 11:42AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 12:10PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 01:19PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 02:14PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 03:09PM |
dc42
It appears to me that the O2 X-arm could be used on the O1 if you reprint the extruder body to have the longer tongue.
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 03:20PM |
Davek0974
dc42
I was not sure whether to suggest that or not, unsure if users would want to reprint a part just to fit another??
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 04:33PM |
ormerod168
Davek0974
dc42
This ad-on (or something like that) is a fast and easy print and IMHO a safer solution for support of the extruder than the longer tongue
Ormerod RepRapPro 3D Printer. Extra support for the extruder:
[www.thingiverse.com]
Erik
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 06:29PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 08, 2014 06:36PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 09, 2014 03:54AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 09, 2014 05:40AM |
dc42
Another (theoretical) possibility: make the parts with the correct dimensions for the O2, but keep the lip at the end of each slot at the top of the arm as on the O1. To use an O2 extruder with the arm, just file the lip down, which should only take a minute or so. This assumes that the width and depth of the slots are the same in both designs apart from the lip, which I haven't checked.
Re: Laser cut Aluminium X-Arm & Rib kits.... December 09, 2014 06:20AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 09, 2014 07:48AM |
Aagaard
What would the price be? Similiar to the previous version?
