Re: Laser cut Aluminium X-Arm & Rib kits.... June 30, 2015 01:48AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 30, 2015 01:13PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 30, 2015 01:37PM |
i've had to file some edges where the bearings run but otherwise very well made.Quote
achaz
I've had mine installed for a few days now. Went together real well. I had a problem with the threading on one of the supplied screws, but I had a spare from some other project handy, and the slot for the washer wasn't clean cut, but a minute with a needle file fixed that right up. The arm looks real sharp on the printer now, can easily see how much more rigid it is than the old acrylic assembly.
Re: Laser cut Aluminium X-Arm & Rib kits.... June 30, 2015 03:30PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 30, 2015 03:35PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 30, 2015 05:08PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 01, 2015 02:41AM |
markdoll01
Hi Dave,
I am really interested in the X-arm upgrade kit for the Ormerod2 but you do not have Namibia listed on your site :-( Any chance you can add Namibia, Windhoek to the list.
Thanks and keep well.
Mark
Re: Laser cut Aluminium X-Arm & Rib kits.... July 01, 2015 03:00AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 19, 2015 04:46PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 30, 2015 06:31AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 05, 2015 10:43AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 06, 2015 12:41PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 06, 2015 05:35PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 07, 2015 05:53AM |
Fpex
Have you ever considered to amke a metallic z base also?
Re: Laser cut Aluminium X-Arm & Rib kits.... August 07, 2015 11:43AM |
Davek0974
Fpex
Any chance you can point me to a picture or DXF link so I can know exactly what part this is please ??
I will have a look at it then
Dave
Re: Laser cut Aluminium X-Arm & Rib kits.... August 07, 2015 12:58PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 07, 2015 01:22PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 07, 2015 01:57PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 07, 2015 02:26PM |
Davek0974
...What would the thickness be, 3mm??
Dave
Re: Laser cut Aluminium X-Arm & Rib kits.... August 07, 2015 03:05PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 08, 2015 12:36AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 08, 2015 09:03AM |
Treito
If you do not mod anything it is important that the thickness is equal with the original thickness otherwise you would not have a stable stand.
Re: Laser cut Aluminium X-Arm & Rib kits.... August 08, 2015 09:12AM |
ormerod168
3) lot of folks mount vibration dampers under their printers anyway
Re: Laser cut Aluminium X-Arm & Rib kits.... August 08, 2015 09:25AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 08, 2015 09:52AM |
Fpex
That is some seriously nice ormerod mod.
Re: Laser cut Aluminium X-Arm & Rib kits.... August 08, 2015 11:49AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 08, 2015 04:01PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 08, 2015 04:25PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 08, 2015 06:06PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 09, 2015 07:56AM |
