Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 08:29AM |
Treito
Maybe you can describe what I can test. What I have to look for in detail. Okay I can bend the standard arm in Y-direction so I would get the biggest problems with high x-values. But does the standard arm really swing that much during printing? (No smartphone. Printing not pregnancy)
I remember that there was a change with my MK1, but I am unsure if this would help with my MK2.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 08:56AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 18, 2016 03:52AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 18, 2016 09:33AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 18, 2016 09:44AM |
steve0-uk
Just paid for mine Dave.
Order no. 941 ☺
Re: Laser cut Aluminium X-Arm & Rib kits.... January 18, 2016 01:06PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 18, 2016 01:32PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 10:49AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 12:53PM |
Treito
Is it too late or can I place an order, too? And if so until when I have to place it? What about a shim without adhesive components?
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 01:20PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 01:27PM |
Treito
Okay, you saw my stainless steel ruler? You said you delivered the first batch with a shim for the running bearing? I want to prevent the same damage like the arm of my MK1. This problem ruined some prints with my MK1. I hoped that your first shim fits better than my ruler as it has to be cut and it has to be made smaller at one end if I use the ruler. But it is not important as I will hopefully could get another ruler.
I asked because I did not want to rob somebody else the X-arm. My printet X-arm is working well and even better than the original acrylic one, but you still see differences to the Aluminium version. And meanwhile I have reflected. My self-made Ormerod 2 should be better than my Ormerod 1 in all points and there is a weak point which probably pretends myself in printing faster and better.
So I just placed my order.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 01:41PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 02:55PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 03:06PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 03:21PM |
Davek0974
It will only work on the version with the bearing running on the back though, i think yours was that one so should be ok.
I only can barely resist. In that case I would have to flip my X-axis and add some sort of arrow to my x-carriage to see the current location on the ruler scale.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 03:27PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 19, 2016 03:30PM |
Davek0974
There are two version believe of x-axis runners - one with the bearing running on th back of the arm and one with it on the underside.
I will send a bit of shim with your order when ready.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 21, 2016 03:07PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 26, 2016 01:39PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 29, 2016 12:10PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 29, 2016 12:43PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 29, 2016 06:24PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 30, 2016 02:22AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 30, 2016 02:26AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 30, 2016 02:51AM |
steve0-uk
unstable
Mine turned up too, thanks a lot. Is it just a straight swap for ormerod 2?
Totally a straight swap. Should take you about 10 mins to swap them over
I have no idea how much time superglue needs to finish. As I fixed my old arm I was not able to move my shim anymore after just 15 seconds or so. Thanks Sven why did you write this? Now I am nervous and writing to myself.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 30, 2016 03:57AM |
steve0-uk
Davek0974
you can do it, use something like Brasso metal polish, its filthy work though, it also marks up easily when polished.[/quote
Might just anodize it instead then
A much better ideaI think you can also dye it a cloud when anodising too.
Yes it is a straight swap, but, there is always a but, it will need some fine fettling with a small file etc, nothing major, its down to personal preference really.
If i did all the finishing then the price would likely double.
Some fine emery paper or cloth will help too, the actual fitting is a doddle, just swap them over and tighten the belt as normal and its away, fitting it on the Mk1 might need a small clip printing to stop the extruder motor twisting but again, not always needed.
Dave
Another RS Ormerod Mk1 meets the world
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 30, 2016 04:04AM |
Treito
steve0-uk
unstable
That is some sort of rumour. On my last batch I had to file some areas. it is long ago, but I think it took me something about 30-60 mins. I am curious how the new batch will look like. But mounting will take me something about 24 hours.I have no idea how much time superglue needs to finish. As I fixed my old arm I was not able to move my shim anymore after just 15 seconds or so. Thanks Sven why did you write this? Now I am nervous and writing to myself.
Your fix was pretty clever though and todays adhesives are well capable of glueing metal to metal in short time.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 30, 2016 08:50AM |
