Re: Laser cut Aluminium X-Arm & Rib kits.... January 30, 2016 09:37AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 30, 2016 12:09PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 30, 2016 02:36PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 06:09AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 06:33AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 06:50AM |
steve0-uk
Hi Dave
I don't know how easy it would be to do and I hope you don't think me rude to say, but would it be an idea to lose the cut out for the z idler washer and nut and put it as a threaded hole?
I have included a pic of where i mean circled in red
what do you think?
Steve
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 06:51AM |
rjmusto
Dave - yes please. Thanks. R
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 07:23AM |
Davek0974
Hi
Not rude of course, sensible question.
The drawing was taken from the original acrylic parts so yes that cutout could very easily be replaced with a tapped hole.
What does everyone else here feel - is there any drawback to swapping the nut cutout for a tapped hole???
Dave
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 07:33AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 08:25AM |
ormerod168
Davek0974
..What does everyone else here feel - is there any drawback to swapping the nut cutout for a tapped hole???
Dave
Your first edition (for ormerod1) was made that way, no problems with those
Erik
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 08:33AM |
Davek0974
ormerod168
Davek0974
Dave
Erik
Really? It was a long while back, cant remember the first batch now
I will remove the slot and fit a threaded hole then.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 08:37AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 08:42AM |
steve0-uk
Davek0974
ormerod168
Davek0974
Dave
Erik
put me down of one on your next batch Dave
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 08:44AM |
orictosh
Just a thought,
That little bolt (nut cut-out) slot is to me a sign that's been made the rap-rap way with laser cutter or any other method.
Adding/replacing it with a tapped hole just adds another process for manufacturer. Can't see the reason for a threaded hole.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 09:01AM |
Davek0974
orictosh
Just a thought,
Looking at it that way, all the holes could be replaced with slots - no threads to tap at all then.
I am open minded as to what is best here, whats the general consensus - leave as-is, replace with threaded hole, replace all threads with slots?
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 09:16AM |
Davek0974
Re: Laser cut Aluminium X-Arm & Rib kits.... January 31, 2016 09:27AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 06:05AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 06:28AM |
andynxn
Could you put me down for the next batch also please
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 06:39AM |
ormerod168
Davek0974
the function of the x-rib is to make/keep the x-axis-plate straight (wider is better) - or to put it another way, the x-axis plate should follow the line of the x-rib, not the other way around
[attachment 71340 x-rib.JPG]
Erik
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 07:35AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 07:47AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 08:00AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 10:56AM |
Treito
Does anyone have a picture showing the polished version?
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 12:10PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 01:01PM |
Davek0974
HI again
As we have now started the next batch of X-arm kits, could I please ask all those that expressed an interest to head on over to my shop
X-ARM KITS HERE
and place their order as they are fist-come-first-served and batch is limited qty.
I would expect dispatch to be within two weeks.
Many thanks
Dave
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 01:25PM |
Treito
..Why is a brushed surface easier to repair?
Thanks Dave for the shim. It's okay for a new part, but for repairing my other one it would have been too thin
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 01:59PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... February 01, 2016 03:14PM |
Treito
Thanks Dave for the shim. It's okay for a new part, but for repairing my other one it would have been too thin. But I am curious. How this is called and how could I get it? It could be of interest for my own design, maybe.
