Re: Laser cut Aluminium X-Arm & Rib kits.... July 08, 2017 05:04PM |
Karoo Klong
How do you find the machine/kit number?
I would really like to know and use it's number.
Re: Laser cut Aluminium X-Arm & Rib kits.... July 11, 2017 08:15AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 15, 2017 09:15AM |
trevmas
..I think the secret is getting the cooling block in the right place..
...and using reasonable retraction settings.
Re: Laser cut Aluminium X-Arm & Rib kits.... July 18, 2017 09:59AM |
ormerod168
I retract 10.0mm at 60mm/sec in the end script and it do not give me any trouble
Erik
Re: Laser cut Aluminium X-Arm & Rib kits.... November 29, 2017 07:39AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 29, 2017 03:36PM |
Davek0974
Hi all,
Christmas is coming - we still supply the bed and arm kits for mk1's and bed kits for mk2's
Re: Laser cut Aluminium X-Arm & Rib kits.... August 31, 2018 02:50AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 02, 2018 04:20PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 02, 2018 05:24PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 28, 2018 05:07AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 20, 2019 09:04AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 08, 2020 05:07AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 08, 2020 05:50AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 08, 2020 08:03AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 08, 2020 09:45AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 08, 2020 10:18AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 08, 2020 11:23AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 08, 2020 11:35AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 08, 2020 11:50AM |
orictosh
Davek0974 made the kit parts for me to order and I sold them upon my website 3DPrint and Stuff, which is now closed.
Might have one on the stock shelf, will need to check.
DaveK0974
Nice to hear they are still running though.
Re: Laser cut Aluminium X-Arm & Rib kits.... May 08, 2020 12:51PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 11, 2020 06:54AM |
PeterSimpson
As Davek0974 rightly guessed, I have a Mk 1 Ormerod printer and the bed support is the single plate as offered on his website at https://ddmetalproducts.co.uk/product/printer-bed-support/
Peter
Re: Laser cut Aluminium X-Arm & Rib kits.... May 11, 2020 07:42AM |
Ormerod168
You could print this one (if you can print that is) - I did in ABS and it works great
One-piece Ormerod bed support:
[www.thingiverse.com]
Re: Laser cut Aluminium X-Arm & Rib kits.... May 11, 2020 01:26PM |
PeterSimpson
As you may have guessed I am not in a position to print anything just yet, so will have to find someone who can do it for me. Does it need to be ABS, or will PLA work just as well?
Re: Laser cut Aluminium X-Arm & Rib kits.... May 21, 2020 05:09AM |
WesBrooks
I'll vouch for the alloy bed plates! Running two sets here, also hammering out face shield frames.
@orictosh hello! The filamentive clear PETG that you sold me when closing down the website is working great on the frames. More than can be said for a alternate 'snow white' PETG which is proving brittle. Did you get left with any more DHT sensors that you would still like to shift? I would be interested if so.
