Re: Laser cut Aluminium X-Arm & Rib kits.... May 16, 2015 06:51AM |
Darathy
Will you still be making the Ormerod Aluminum X Plate in abaut 1 month? and is it compatible with Ormerod 2?
Re: Laser cut Aluminium X-Arm & Rib kits.... May 16, 2015 02:18PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 16, 2015 02:30PM |
Europa
Hi Dave, assuming the part would be posted in the UK I would like to order one of the aluminium X plates for my Ormerod 2 please.
Brian
Re: Laser cut Aluminium X-Arm & Rib kits.... May 18, 2015 04:34PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 18, 2015 04:37PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 21, 2015 08:48PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 22, 2015 03:56AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 27, 2015 08:11AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 12:00PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 12:34PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 03:06PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 03:22PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 03:31PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 03:43PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 03:58PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 04:19PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 04:38PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 05:01PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 05:15PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 05:26PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 30, 2015 05:27PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... May 31, 2015 03:43AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 01, 2015 11:28AM |
Treito
...the bearing is on the downside. this version should also be working with my Ormerod. The advantage shall be that it raises the stability of the X-arm...
Re: Laser cut Aluminium X-Arm & Rib kits.... June 01, 2015 12:30PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 01, 2015 01:13PM |
Treito
Thanks Erik,
I know.but the new part will theoretically work with the arm, too, won't it? Only the nozzle mount may not work.. The new x-carriage offers more space for the sensor and maybe I would like to exchange it to the 4-pin variant, but I am not sure for the moment.
Sven
Re: Laser cut Aluminium X-Arm & Rib kits.... June 01, 2015 01:45PM |
Darathy
Treito
Thanks Erik,
Sven
Well i did notice that the underside of the Alu X plate is a bit rough becouse of the way it is cut,so mybe it wont be ideal. It will probably impact slightly on the quality of the prints.
Re: Laser cut Aluminium X-Arm & Rib kits.... June 01, 2015 02:08PM |
Treito
Darathy
Treito
Thanks Erik,
Sven
This is a statement that I can use. So I stay better with the old version. As you say this it totally does make sense. I did not think about this but I should have think about it. The surface of the side will be smoother and I finally got a good print of the x-carriage from iamburny so I have the possibility to change the position of the rod. And to be sure I already ordered a new bigger rod. (10mm instead of 9mm).
Re: Laser cut Aluminium X-Arm & Rib kits.... June 01, 2015 02:13PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 04, 2015 03:46AM |
