Re: Laser cut Aluminium X-Arm & Rib kits....
January 30, 2016 09:37AM
Thanks Treito, good explanation of the issue.
It definitely takes more than 10mins to fit, took me about an hour as I wanted to get everything set just so, no point in rushing this stuff.
I am nearly at the point where I can start another batch. smiling smiley
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
January 30, 2016 12:09PM
Dave,
Got any left from this batch?
Thanks,
Ralph
Edited 1 time(s). Last edit at 01/30/2016 12:09PM by rjmusto.
January 30, 2016 02:36PM
Hi
no but i can put your name on the list for the next batch.
Should not be long before i get enough interest to get going now.
Dave
January 31, 2016 06:09AM
Hi Dave
I don't know how easy it would be to do and I hope you don't think me rude to say, but would it be an idea to lose the cut out for the z idler washer and nut and put it as a threaded hole?
I have included a pic of where i mean circled in red
what do you think?
Steve
open | download - Untitled.png (1.9 KB)
January 31, 2016 06:33AM
Dave - yes please. Thanks. R
January 31, 2016 06:50AM
steve0-uk
Hi Dave
what do you think?
Steve
Hi
Not rude of course, sensible question.
The drawing was taken from the original acrylic parts so yes that cutout could very easily be replaced with a tapped hole.
What does everyone else here feel - is there any drawback to swapping the nut cutout for a tapped hole???
Dave
January 31, 2016 06:51AM
rjmusto
Hi
Yes you would like an arm kit or yes you would like me to remove the nut cutout, or both ??
smiling smiley
January 31, 2016 07:23AM
Davek0974
Hi
Dave
glad you are OK with it, the only drawback I can think of is that that hole is bigger than the fixing screws to hold the 2 parts together meaning the rib might need to be thicker to be able to take the thread
I guess it would make the tool path simpler as it wont need to cut that bit out
Steve
January 31, 2016 07:33AM
Davek0974
..What does everyone else here feel - is there any drawback to swapping the nut cutout for a tapped hole???
Dave
Your first edition (for ormerod1) was made that way, no problems with those
Erik
January 31, 2016 08:25AM
ormerod168
Davek0974
Dave
Erik
Really? It was a long while back, cant remember the first batch now winking smiley
I will remove the slot and fit a threaded hole then.
January 31, 2016 08:33AM
Davek0974
ormerod168
Davek0974
Dave
Erik
put me down of one on your next batch Dave smiling smiley
January 31, 2016 08:37AM
Just a thought,
That little bolt (nut cut-out) slot is to me a sign that's been made the rap-rap way with laser cutter or any other method.
Adding/replacing it with a tapped hole just adds another process for manufacturer. Can't see the reason for a threaded hole.
Supporting 3D Printers with Parts and Build services.
Printer: Ormerod 2 (528.4) Duel extruder set-up with Aluminium X-Rib, RRPro Firmware v1.11-ch (2016-04-08)
January 31, 2016 08:42AM
steve0-uk
Davek0974
ormerod168
Davek0974
Dave
Erik
Will do, thanks, I think we are just about there with the pre-orders now smiling smiley
January 31, 2016 08:44AM
orictosh
Just a thought,
Looking at it that way, all the holes could be replaced with slots - no threads to tap at all then.
I am open minded as to what is best here, whats the general consensus - leave as-is, replace with threaded hole, replace all threads with slots?
January 31, 2016 09:01AM
Davek0974
orictosh
Just a thought,
i'd rather the threaded hole, but i'll go with the majority vote
January 31, 2016 09:16AM
Davek0974
the function of the x-rib is to make/keep the x-axis-plate straight (wider is better) - or to put it another way, the x-axis plate should follow the line of the x-rib, not the other way around
Erik
January 31, 2016 09:27AM
Ok, so that says replace the slot with a tapped hole then, makes sense.
February 01, 2016 06:05AM
Could you put me down for the next batch also please thumbs up
February 01, 2016 06:28AM
andynxn
Yes of course, should be starting this week smiling smiley
Will let everyone know
February 01, 2016 06:39AM
ormerod168
Davek0974
[attachment 71340 x-rib.JPG]
Erik
Seems that picture is incorrect, as the x-rib which is fitted to my printer shows a bump behind the bolt hole, can't exactly remember when it was ordered but it's no longer than 6 months. I should be able to check the paper work and report back.
February 01, 2016 07:35AM
I hope I can fetch up my X-arm this evening. On one side I regret not to have the newer idea without the slot, but at least: For what? In my eyes there is no difference. Also the treaded holes could be slots. I guess this could maybe reduce the manufacturing costs.
But I would like to reask for the polish. Is there no coating on the kit? Could I use some normal car polish?
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
February 01, 2016 07:47AM
That bump has now gone as it was only there to reinforce the weaker acrylic part where the nut slot was.
I will start a new batch now as we have enough interest, the slot has been replaced with a threaded hole, again this appeared to only be there because you cannot easily thread acrylic parts, aluminium is far easier to work with so the new batch will have no bump and no nut slot.
For polishing aluminium use a fairly aggressive polish like Brasso or Solvite Autosol for cars (not that theres much to polish on a modern car!) - both of these will work but be warned, when you polish aluminium you will get covered in black muck so best use rubber gloves and put some newspaper down smiling smiley
February 01, 2016 08:00AM
Does anyone have a picture showing the polished version?
I am glad now to have the bump. Maybe I will test a design for a mechanical z-probe and depending on the design you could use the bump for homing the x-axis, too.
HI again
As we have now started the next batch of X-arm kits, could I please ask all those that expressed an interest to head on over to my shop
X-ARM KITS HERE
and place their order as they are fist-come-first-served and batch is limited qty.
I would expect dispatch to be within two weeks.
Many thanks
Dave
February 01, 2016 10:56AM
Treito
polishing a spot on a spare x-arm as an example is easy, to make it show on a picture is the hard part - personally I prefer a brushed finish, much easier to repair
Erik
February 01, 2016 12:10PM
Did I say I am glad to have the bump? Forget about it. grinning smiley
Thanks Erik. First of all I wasn't sure if there is some sort of coating for protection. Why is a brushed surface easier to repair?
At least I haven't decided yet what is looking better.
Thanks Dave for the shim. It's okay for a new part, but for repairing my other one it would have been too thin. But I am curious. How this is called and how could I get it? It could be of interest for my own design, maybe.
February 01, 2016 01:01PM
Davek0974
HI again
X-ARM KITS HERE
Many thanks
Dave
Dave
can I be really cheeky, could you reserve mine for me please?
I get paid on the 15th of every month, I will pay you that morning as soon as I get to a computer
I'll throw in a bit extra for ya for the trouble
February 01, 2016 01:25PM
Treito
..Why is a brushed surface easier to repair?
Its a lot faster to apply and repair (brush or sand) a rougher surface than a mirror finish, I use P400 wet and dry sandpaper and sand along the x-arm (not in circles)
Still got the 12.7 steel strap, my offer still stands if you are interested, the weight is 13gram, adding a cardboard tube for posting totals 70gram so could be send to Germany for €3....could ad a few drops of Loctite 648 but only if you say please :-)
Erik
February 01, 2016 01:59PM
Thanks for your offer. I would have expected that shipping costs are much higher, but the ruler wasn't expensive, too.
Besides like I said the delivered shim is totally okay as long as the surface is even. So I will use this shim as protection. It is only very thin, I would guess something about 0.1mm. It is equipped with adhesive already. I really would like to compare both solutions. Okay optically your shim would be the best solution as its width is the same like the height of the bottom line of the X-arm to the upper line of the X-thing at the front of the X-arm. That's offers of course a great optically experience. Seriously.
February 01, 2016 03:14PM
Treito
The tape is simply called shim tape, its used in my day-job which is die-cutting and printing, see if you have a printers supplies company near you, ask for self adhesive stainless shim tape, comes in two thicknesses - 0.1mm and 0.2mm, the one i use is 0.2mm.
If you get desperate i could get a price for a full roll over here and sell you it??
Dave
Edited 1 time(s). Last edit at 02/01/2016 03:18PM by Davek0974.
